A6 4F Drive Select Settings
Wanninger
Post09-12-2024, 18:12    Subject: A6 4F Drive Select Settings Quote
Hello everyone,
Due to unforeseen circumstances, I had to quickly acquire a "new" Audi A6 (4F C6 [Quattro] from 2010) because my old C7 is no longer working.
I would now like to adjust the steering to be a bit firmer, and possibly also the engine, similar to how it was possible in my C7 using the Drive Select feature.
After reading quite a bit of information about it online, I only ever found explanations for the A4 and A5 series. Unfortunately, there is absolutely nothing about the A6.
For these models (A4/A5), the coding is entered in the "09 Central..." "BCM1" control unit.
My problem is that I can't see a control unit with the name "BCM1" using VCDS. It doesn't appear in the 09 menu, or anywhere else. However, there is likely a similar module available for my A6, as it is also offered under that name on the INET platform.
Does anyone have a tip or trick for me, or is there a guide for enabling the Drive Select feature in an A6 4F? It would also be sufficient for me if I could code the steering and, if necessary, the engine to be statically stiffer (set to Dynamic).
Thank you very much, and best regards.
Wanninger.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
Post09-12-2024, 21:31    Subject: A6 4F Drive Select Settings Quote
Good evening, Wanninger.
In the scan, your BCM 01 is displayed as control unit 09.
You can read about the necessary steps and adjustments here:
https://www.audienthusiasts.com/Project_ADS.html
Make sure to do a scan beforehand so you can reset everything if needed.
I would appreciate it if you could let me know whether the process was successful or not.
Michael.
Wanninger
Post09-12-2024, 22:38    Subject: A6 4F Drive Select Settings Quote
Hello Michael, and thank you for the quick response.
I proceeded exactly according to the Project_ADS guidelines.
But unfortunately, under control unit 09, I only see "ILM Driver," "Wiper Audi C6," and "RAIN SENSOR H04."
I have tried this with both VCDS version 17.1.3 and VCDS version 24.7.1. I would have also liked to test it with my old VCDS versions 10.6.4 or 11.11.4, but I can't establish a (CAN bus) connection to the car with those versions.
Attached are some screenshots that show this as well. I have also included the connection test.
Best regards, Günter.
 File size:  98.06 KB
 Viewed:  1311 times
 File size:  167.3 KB
 Viewed:  1236 times
 File size:  151.57 KB
 Viewed:  1221 times
 File size:  139.55 KB
 Viewed:  1220 times
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts VAGCOM Settings: What Do They Mean? Diesel Engine Technology
No new posts Polo 9N: Adjust Service Interval Settings On-Board Diagnostics (OBD)
No new posts Create VCDS label template, Engine control unit mapping s... On-Board Diagnostics (OBD)
