Common rail diesel: Fuel line leak, need to bleed?
stolley
Karma: +38 / -1   Thank you, like it!
Post28-03-2025, 21:33    Subject: Common rail diesel: Fuel line leak, need to bleed? Quote
Dear friends,
I now have the opportunity to work on a common-rail diesel engine for the first time.
My daughter's Polo 6R (2015 model year) has a fuel line leak in the engine compartment.
The exchange shouldn't be a problem. I'm just wondering if I need to take any precautions when starting the engine after the repair. Or do I need to somehow bleed the fuel system?
Thank you all!
Translated on 06-07-2026, 9:51.
dieselschrauber likes this.
Post29-03-2025, 7:20    Subject: Common rail diesel: Fuel line leak, need to bleed? Quote
Of course, you should bleed it. As with a filter change, run the fuel pump using VCDS. And work cleanly.
Translated on 06-07-2026, 9:52.
stolley
Post29-03-2025, 7:43    Subject: Common rail diesel: Fuel line leak, need to bleed? Quote
Great, thanks Herbert!
Volker.
Translated on 06-07-2026, 9:53.
No new posts Custom Fuel Lines: Transparent & High-Performance Troubleshooting & Guides
No new posts Fuel system bleeding - Audi A4 3.0 TDI BKN Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 3.0 TDI Commonrail: Low fuel pressure Diesel Engine Technology
No new posts Help 3.0TDI Commonrail - No Rail Pressure Diesel Engine Technology
This topic is locked, you cannot edit or reply. Air Bubbles in Fuel Line: Causes & Fixes Diesel Engine Technology
No new posts Fuel Leak: Causes & Solutions Diesel Engine Technology
