I'm editing the post because new developments have occurred in the meantime.
"This refers to the following vehicle:"
- Skoda Superb 3U4 1.9 TDI AWX, 06/05, 131 hp, ~475,000 km, approximately 300,000 km ago, performance optimization via MSG adjustment, AGR valve "disabled" using a plate during the process.
Auto-scan VCDS:
Sunday, August 3, 2025, 10:04:04:48728.
VCDS, a Windows-based VAG/VAS emulator, now runs on Windows 11 x64.
VCDS Version: DRV 24.7.1.0
Data as of: 20241105 DS356.3
shop.dieselschrauber.org
Dealer/Workshop name: Daniel.
Vehicle Identification Number (VIN): TMBBU63UX5xxxxxxx
License plate:
Mileage: 473,150 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 3U (3U - Skoda Superb I (2002 > 2008))
Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76
Vehicle Identification Number: TMBBU63UX5xxxxxxx
Mileage: 473,150 km
Address 01: Engine Control Module
Label file: DRV\038-906-019-AVF.lbl
Part number: 038 906 019 KE.
Part: 1.9L R4 EDC G000SG 4898
Coding: 00005
Operating number: WSC 36345.
VCID: 64C0141FF4E5E7B64F-4B1A
TMBBU63UX59089948 SKZ7Z0D2790065
"One error found:"
18263 - Data bus driver.
P1855 - 35-10 - Software Status Monitoring - Intermittent.
Readiness: 0 0 0 0 1 0
Address 03: Brake Electronics
Label file: DRV\3U0-614-517.lbl
Part number: 3U0 614 517 D
Component: ABS/ESP front 1314
Coding: 04255
Operating number: WSC 00028
VCID: 3460A45F048537361F-5122
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\3U0-907-044.lbl
Part number: 3U0 907 044 A
Part: CLIMATRONIC S B5 C 2004
Encoding: 17000
VCID: 316EAD4BFB97021E74-515E
"One error found:"
01271 - Temperature flap actuator (V68)
37-00 - defective.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 F
Part: 0D AIRBAG VW61 0K 0003
Encoding: 12356
VCID: 275A4313C5534CAEAA-5122
Address 16: Steering wheel electronics
Label file: DRV\1J0-907-487-A.lbl
Part number: 1J0 907 487 A
Component: Steering wheel electronics 0005.
Encoding: 00118
VCID: 2F6AAB33EDA314EE62-515E
"One error found:"
01336 - Corporate Data Bus Comfort.
80-00 - in single-wire operation.
Address 17: Control panel module
Label file: DRV\3U0-920-xxx-17.lbl
Part number: 3U0 920 841 A
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V06
Encoding: 23105
Operating number: WSC 00000
VCID: 316EAD4BFB97021E74-5122
2 error codes found:
49-10 - No communication - Intermittent.
00476 - Control unit for fuel pump (J538)
49-00 - No communication.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.clb
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: 70E8684F301D4B163B-5122
4 error codes found:
00463 - Control unit for the Digital Sound Package (J525).
01303 - Transmitting and receiving device for telephone (R36).
Address 36: Seat adjustment for driver.
Label file: DRV\3B1-959-760.lbl
Part number: 3B1 959 760 E.
Component: °301
Operating number: WSC 00000 065 00000
VCID: 2F6AAB33BDA314EE62-5122
Address 37: Navigation
Label file: DRV\3B0-919-887.lbl
Part number: 1U0 919 887 BX
Component: Navigation BNO 0102
Encoding: 00002
VCID: 1A3C6AE78621E14625-4B00
"One error found:"
00862 - Antenna for navigation (GPS) (R50)/(R52)
44-10 - Short circuit - Intermittent.
Address 46: Comfort System
Label file: DRV\1C0-959-799.lbl
Part number: 1C0 959 799 B.
Component: BD Comfort Device HLO 0004.
Encoding: 00259
VCID: 36649E5712F9252621-4B1A
Subsystem 1 - Part number: 1C0959801.
Component: BD Throttle Control.FS KLO 0202
Subsystem 2 - Part number: 1C0959802A
Component: BD Throttle Control.BF KLO 0202
Subsystem 3 - Part number: 3U0959811.
Component: BD Throttle Control.HL KLO 0202
Subsystem 4 - Part number: 3U0959812.
Component: BD Throttle Control.HR KLO 0202
3 error codes found:
37-10 - defective - intermittent.
00930 - Rear left central locking control unit (F222)
27-10 - implausible signal - sporadic.
Address 47: Soundsystem
Label file: DRV\1J0-035-456.lbl
Part number: 3U0 035 456 B
Component: Sound processor 3.
Coding: 00571
VCID: 316EAD4BFB97021E74-4AE8
Address 56: Radio
Label file: DRV\3B0-035-186.lbl
Part number: 3B0 035 186 DX
Component: Radio BNO 0102
Encoding: 00400
Operating number: WSC 56405
VCID: 78F8506F586D1356F3-4AE8
00852 - Front speakers.
36-00 - Interruption.
00853 - Rear speakers.
Address 76: Parking Assist
Label file: DRV\3U0-919-283-7X1.lbl
Part number: 3U0 919 283.
Component: Parking Assist System V009
Encoding: 00114
VCID: 78F8506F586D1356F3-4BB0
End----------------------------(Duration: 02:51)-----------------------------
"Recently, I've been experiencing the following problem with my car: A few weeks ago, I occasionally (sometimes twice during a commute to work, which is about 40km each way) experienced a brief, hard jolt. The idle was normal, there was full power, no excessive soot when accelerating, and no increased fuel consumption. We then replaced the diesel filter and the gasket for the valve on the filter (manufacturer UFI). After that, things were quiet for a few days, and we thought we had found the problem."
"Now, it seems that the engine almost regularly, but not constantly, experiences a misfire at idle, which causes the engine speed to drop briefly by about 100 RPM. Once, it even stalled in the morning, but it started without any problems. Yesterday, it also stalled when I was disengaging the clutch to approach a traffic light. However, it started immediately again, and I was able to continue driving normally. The engine performance is as expected, and it accelerates properly."
"It now idles roughly on a regular basis, but the problem disappears when I accelerate. I suspect a fuel supply issue, specifically with the tandem pump."
Yesterday, we replaced the PD wiring harness (original VW) and the valve on the diesel filter, but there was no improvement.
The colleague from the other forum, based on the video, expressed a rather clear suspicion of a tandem pump issue. I already purchased a replacement from Pierburg a few months ago, and we will be replacing it tonight, hoping to solve the problem.
If that's not the problem, would you know what else could be causing these symptoms?
Thank you in advance for your thoughts and assistance!
Daniel
