300355
14-07-2025, 12:44 Subject: Turn Signal Lights in Fog Lights |
Good day.
Ich habe einen Golf 7 Bj 2013.Die Nebel-Lampen gehen.Aber das Abbiegelicht ist ohne Funktion. VCDS writes.
Right turn signal, C1084 13 (00001001), interruption.
Who can help? If the right side has a break, why isn't the left side working either?
Sincerely, R. Schelert.
Translated on 18-09-2026, 2:15.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
14-07-2025, 20:40 Subject: Turn Signal Lights in Fog Lights |
Obtain a wiring diagram for the vehicle (Erwin). There may be specific cables for the cornering lights leading to the lamps, and make sure that the cornering light function is actually implemented using the fog lights and not the headlights.
Please provide the complete car scan.
Translated on 18-09-2026, 2:16.
Profile PM WWW Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2405 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
dieselschrauber likes this. |
15-07-2025, 11:05 Subject: Turn Signal Lights in Fog Lights |
The Golf 7 comes with various different types of headlights. Sometimes the cornering light is integrated into the fog lights, while in other cases it's a separate light source within the main headlight unit. It seems like your car has the latter type.
Test: Turn on the lights. Activate the left turn signal and turn the steering wheel to the left. Compare the left and right headlights. It's likely that the side that's defective will be the one that's not lit up.
We already had an article about the different types of headlights available for the Golf 7 earlier this year.
Translated on 18-09-2026, 2:17.
Profile PM Garage |
Profile PM Garage |
300355
dieselschrauber and Bertil likes this. |
29-07-2025, 8:48 Subject: Golf 7: Turn Signal Problems & Fixes |
This Golf doesn't have cornering lights in the fog lights. It only has the cornering light integrated into the headlight.
Due to a faulty bulb, the other side was also shut down.
Translated on 18-09-2026, 2:18.
