SQ5: Disable 8R AGR & Oil Pressure Upgrade?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post29-07-2025, 21:27    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
Hello everyone,
After several years, I'm back in the forum.
I've been driving an Audi SQ5 8R with 326 horsepower for a few months. CVUB.
I'm increasingly reading about factory-set oil pressure that is too low in the lower RPM range, as well as an EGR system that works too aggressively, which can lead to more problems with the engine after higher mileage.
Is this just marketing hype from some chip tuners, or are these facts really worth considering?
I always keep my vehicles for at least 10 years, even with higher mileage, and I'd like to do something good for them if it makes sense.
Therefore, I would appreciate hearing your opinions on this topic!
Audi SQ5 8R Cvub
Translated on 25-08-2026, 2:28.
Back to top Profile PM Email
dieselschrauber likes this.
Post30-07-2025, 18:43    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
I once saw a video about the oil pressure issue in the Audi 3.0 TDI engine.
I believe it's probably electronically limited for emissions reasons, but that can be reprogrammed.
Translated on 25-08-2026, 2:30.
pa-mm6
Post30-07-2025, 22:39    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
Hi Rudi, thanks for your reply. I've seen that before, but I would like to hear the opinion of the experts on this. Does it make sense, or is the oil pressure sufficient on its own?
Audi SQ5 8R Cvub
Post30-07-2025, 23:41    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
You're unlikely to find true professionals here who are experienced in engine building or repair.
Too much oil pressure isn't necessarily good, but too little is bad.
The V6 diesel engines from Mercedes have similar problems, but these are caused by an undersized oil pump.
Translated on 25-08-2026, 2:31.
Karma: +1343 / -0   Thank you, like it!
Post31-07-2025, 9:48    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
Is there a link to the video?
Post31-07-2025, 20:20    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Translating...
[Translating...]
https://youtu.be/zPby1E73WGY?feature=shared
Post01-08-2025, 5:29    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
The principle of regulated oil pressure with a reduction down to 2500 min-1 is described for the EA288 engine (i.e., R4 TDI and R3 TDI engines) in documents SSP514 and SSP534, and for the EA288 EVO engine in document SSP595.
For the V6 TDI engine, you can find information in SSP428. For its later developments (V6 TDI Generation 2), it is mentioned in SSP479, SSP495, and SSP581 (EA987 Generation 2).
So, for all models starting around 2014.
Translated on 25-08-2026, 2:32.
pa-mm6
Post01-08-2025, 6:14    Subject: SQ5: Disable 8R AGR & Oil Pressure Upgrade? Quote
Okay, Herbert, I'll go ahead and study the SSP then.
Audi SQ5 8R Cvub
Translated on 25-08-2026, 2:33.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disable automatic locking on Audi A4 B9 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 - How can I turn off/disable the daytime running ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts AJM & LMM by ARL: Feasible and Useful? Diesel Engine Technology
No new posts DPF bei Leistungssteigerung sinnvoll??? Diesel Engine Technology
