Interior lighting / door lights defective (for Golf IV / Bora) (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Joner
dieselschrauber and Herbert likes this.
Post02-10-2025, 8:34    Subject: Interior lighting / door lights defective (for Golf IV / Bora) Quote
In my Bora 1J6, the interior lighting, including the door indicator lights, has completely failed. After a long search, I found the culprit. In the wiring harness that runs along the A-pillar, several blue/red wires were crimped together. This "connection point" had completely disintegrated (with green corrosion). The "connection point" is completely embedded within the wiring harness, which is why the problem isn't visible from the outside.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Translated on 15-07-2026, 14:20.
Post03-10-2025, 11:30    Subject: Interior lighting / door lights defective (for Golf IV / Bora) Quote
Hi, thanks for the information! Could water be getting in somewhere, perhaps from a windshield that wasn't installed correctly?
Translated on 15-07-2026, 14:21.
Joner
dieselschrauber likes this.
Post05-10-2025, 16:49    Subject: Interior lighting / door lights defective (for Golf IV / Bora) Quote
Some time ago, the water tank was leaking. I'm not sure if this is related to the current issue, or if it's due to the humidity and salt buildup in the footwell, especially during the winter months.
Ratings - Interior lighting / door lights defective (for Golf IV / Bora)
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery drain troubleshooting for Golf IV and Bora Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MSTG: Compatible with Golf, Bora, Octavia, A3? On-Board Diagnostics (OBD)
No new posts VW T4 Interior Lights: Upgrade & Replacement Diesel Engine Technology
No new posts Door Sensor for Interior Lighting Diesel Engine Technology
No new posts Flickering Interior Lights: Causes & Solutions Diesel Engine Technology
