Ground loops: An invisible threat to expensive diagnostic equipment (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » General Tips
Karma: +795 / -0   Thank you, like it!
Post18-12-2025, 17:42    Subject: Ground loops: An invisible threat to expensive diagnostic equipment Quote
Ground loops: An invisible threat to expensive diagnostic equipment – Here's how to protect your HEX-V2 and HEX-NET interfaces.
A warning to all VCDS users!
If your HEX-V2 or HEX-NET suddenly stops working, or if your computer's USB ports are being damaged, a ground loop (also known as potential equalization current) might be the culprit. This technical problem occurs more frequently than many people think, and it regularly leads to irreparable damage to diagnostic hardware.
What is a mass loop?
Every diagnostic interface – including high-quality devices like the HEX-V2® or HEX-NET® – connects two electrically isolated systems:
  • The vehicle's electrical circuit (OBD port, 12V/24V on-board network).
  • The computer circuit (USB port, 5V USB power).
Under certain conditions, a voltage difference can develop between the vehicle's chassis and the computer's ground. This difference needs to be balanced – and it happens through your expensive diagnostic interface! These currents can permanently damage protective circuits and processors.
Typical everyday danger situations:
  • Double-plug chargers: Notebook charger plugged into a wall outlet + smartphone charger plugged into the cigarette lighter socket.
  • External computer power supply: a 12V-230V inverter that powers the computer from the vehicle's electrical system.
  • Contact with vehicle voltage: Metal parts of the notebook (e.g., The housing screws may come into contact with the positive terminals in the vehicle.
  • Hybrid/electric vehicles: This is where particularly high potential differences occur.
  • Varying work locations: Different workshop areas with varying grounding.
The devastating consequences:
Damage to HEX-V2 or HEX-NET caused by improper grounding will void the warranty! These damages are excluded by the manufacturer and must be paid for out-of-pocket.
  • Permanent processor damage at the interface.
  • Damaged protection circuits.
  • Damaged USB ports on the computer (often multiple at the same time).
  • Total functional failure of the diagnostic adapter.
  • Repair costs: usually higher than the cost of buying a new one.
The solution: USB isolators
Fortunately, there is a simple and effective solution: USB isolators with galvanic isolation. These devices are connected between the computer's USB port and the diagnostic interface, completely isolating the two circuits while still allowing USB data transfer to function.
Two proven products for different requirements:
For professional VCDS users:
USB isolator for HEX-V2 and HEX-NET
For universal applications:
USB Isolator, universal
Practical recommendations:
  • Prevention is cheaper than repair: A USB isolator can prevent significant damage, and a faulty computer or diagnostic device doesn't have to be a certainty.
  • Always isolate during mobile deployments: When the computer is powered externally.
  • Particularly at risk: Users with laptops connected to external power supplies and educational institutions.
  • Regularly check: Perform an interface test in VCDS.
  • Act immediately at the first signs: USB port problems, intermittent connection drops.
Conclusion:
Ground loops are not a theory – they regularly damage expensive diagnostic equipment. Investing in a USB isolator is not an unnecessary expense, but rather an insurance policy for your hardware. Owners of HEX-V2 or HEX-NET devices should especially ensure proper isolation when:
  • They work on various vehicles/locations.
  • External power supply is used.
  • Connect chargers to both the vehicle and the computer simultaneously.
  • They are working on hybrid/electric vehicles.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Ratings - Ground loops: An invisible threat to expensive diagnostic equipment
No new posts Air Mass Sensor: Expensive Weakness in VW/Audi TDI Technical Articles
No new posts OBD Scanners & VCDS: Diagnose Tools On-Board Diagnostics (OBD)
No new posts 10 ct Tuning und die Gefahr von Kolbenanschmelzungen Diesel Engine Technology
No new posts OBD diagnostic tools without subscription traps On-Board Diagnostics (OBD)
No new posts Who offers the highest LD overswing? ZKD hazard? Diesel Engine Technology
