MAP sensor G71
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post16-06-2026, 8:52    Subject: MAP sensor G71 Quote
The older Audi 2.5 TDI engines with codes AAT/AEL have an external sensor for measuring the intake manifold pressure.
Can the signal from the G71 be processed and displayed digitally?
One would then have a digital display for the charging pressure.
Post16-06-2026, 12:43    Subject: MAP sensor G71 Quote
Hello Jens,
"In my Audi A3 8P, I had something like this installed:"
https://community.dieselschrauber.org/en/viewtopic.php?t=3232
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Engine: Intake Manifold Pressure Sensor Location On-Board Diagnostics (OBD)
No new posts V6 TDI Intake Manifold Pressure Diesel Engine Technology
No new posts AFN Intake Manifold Pressure Error Code On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Regulation Difference Upload
