Audi A3 TDI: Engine Failure at 110 HP
HeizoelpowerA3
Post18-06-2003, 17:55    Subject: Audi A3 TDI: Engine Failure at 110 HP Quote
Hello everyone,
ich habe ein kleines Problem. Mein Auto ist in der letzten Zeit drei mal stehen geblieben. Das heist, ich bin unterwegs gewesen und auf einmal ist der Motor ausgegangen, die Öllampe leuchtet und es pfeifft ein Warnton. Kann mir da einer weiterhelfen? That would be really great.
Translated on 20-10-2026, 4:45.
Post18-06-2003, 22:17    Subject: Audi A3 TDI: Engine Failure at 110 HP Quote
Hi.
Relay 109 faulty?
Tank (almost) empty?
How was the starting behavior and the performance after it turned off?
Translated on 20-10-2026, 4:46.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post19-06-2003, 7:21    Subject: Audi A3 TDI: Engine Failure at 110 HP Quote
With a high degree of certainty, relay 109.
The gauges are dropping, the warning light is beeping, and then, eventually, it starts up again.
Increased frequency at high ambient temperatures and when operating at full throttle.
The error memory is not reporting because this relay is supplying it with power.
The best way is to remove the lower trim piece under the steering wheel and see if you can find the old gray part.
or you have installed the new red relay.
Translated on 20-10-2026, 4:47.
HeizoelpowerA3
Post25-06-2003, 5:48    Subject: Audi A3 TDI: Engine Failure at 110 HP Quote
Hello Tagessuppe,
Thank you for the excellent answer, it helped me a lot. I replaced the relay and since then, I haven't had any more motor shutdowns.
Sure, no problem.
Translated on 20-10-2026, 4:48.
Tagessuppe
Post25-06-2003, 6:59    Subject: Audi A3 TDI: Engine Failure at 110 HP Quote
Please, you're welcome icon_smile.gif.
Glad I could help.
"LG."
This is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes."
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Engine Failure: Causes and Solutions Diesel Engine Technology
No new posts My 110hp Audi TDI with the AFN engine is misfiring when i... Diesel Engine Technology
No new posts TDI (110 hp) engine failure! Diesel Engine Technology
No new posts TDI Power Loss: Troubleshooting & Solutions Diesel Engine Technology
