Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015
Marc332
dieselschrauber likes this.
Post15-08-2026, 14:44    Subject: Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015 Quote
Hello everyone,
We have a big problem: the fuel injection pump was removed without being secured from the rear.
The impeller (located within the chain case) has obviously sagged slightly, which means the high-pressure pump (CP4) cannot be mounted. While I can easily lift the impeller into the desired position with a screwdriver (the chain tensioner hasn't engaged), it doesn't stay in place. To access the impeller from the back, I would have to remove the entire turbocharger, which I honestly want to avoid.
Does anyone have any ideas on how to solve this problem?
Is there a way to position the pump rotor and apply tension via the crankshaft so that the rotor stays in place? It's essentially suspended like in a hammock and held by the chain, or perhaps by the driver-side engine mount (which connects to the camshaft)?
I would be very grateful for any helpful tips.
Best regards and have a nice weekend.
 File size:  8.41 MB
 Viewed:  99 times
Translated on 16-08-2026, 13:37.
Post16-08-2026, 13:33    Subject: Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015 Quote
Hi, I'm not sure, maybe try lifting the impeller with a strong magnet? But make sure the magnet is securely attached, so it doesn't fall in or get stuck inside, which would create another problem.
Translated on 16-08-2026, 13:34.
Marc332
Post16-08-2026, 13:52    Subject: Best SEO Agency: Find Top Agencies Now! Quote
Hi Rainer, no, that won't work. It requires completely removing the turbo and disconnecting the pump from the back. That's why I'm still looking for another solution. I don't think rotating the KW (wastegate) counter-clockwise will help; in the worst case, it could release the chain tensioner, which would be a disaster because then the engine might have to come out, or at least the transmission etc.
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe Grüße", which means "Warm greetings" in English.
Translated on 16-08-2026, 13:53.
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 2015 3.0 TDI Quattro Steering Gear Replaced Transmission, Chassis, Body & Interior
No new posts Audi A6 AKE Fuel Pump Immobilizer On-Board Diagnostics (OBD)
No new posts Audi TDI AEL: Faulty Fuel Injection Pump? Diesel Engine Technology
No new posts Retrofitting DAB+ radio for Seat Ibiza 6J FR SC 2.0 TDI, ... Electrical Systems, Vehicle Electronics, Multimedia
