Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015
Marc332
Post15-08-2026, 14:44    Subject: Fuel Injector Pump 3.0 BiTdi 320HP Audi A6 4G 2015 Quote
Hello everyone,
We have a big problem: the fuel injection pump was removed without being secured from the rear.
The impeller (located within the chain case) has obviously sagged slightly, which means the high-pressure pump (CP4) cannot be mounted. While I can easily lift the impeller into the desired position with a screwdriver (the chain tensioner hasn't engaged), it doesn't stay in place. To access the impeller from the back, I would have to remove the entire turbocharger, which I honestly want to avoid.
Does anyone have any ideas on how to solve this problem?
Is there a way to position the impeller and apply tension via the crankshaft so that the impeller stays in place? It's essentially suspended like in a hammock and held by either the chain or the right-side engine mount (which connects to the camshaft).
I would be very grateful for any helpful tips.
Best regards and have a nice weekend.
 File size:  8.41 MB
 Viewed:  10 times
Translated on 15-08-2026, 14:46.
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 2015 3.0 TDI Quattro Steering Gear Replaced Transmission, Chassis, Body & Interior
No new posts Audi A6 4b AKE Einspritzpumpe Wegfahrsperre On-Board Diagnostics (OBD)
No new posts Einspritzpumpe Audi TDI AEL defekt ? Diesel Engine Technology
No new posts Retrofitting DAB+ radio for Seat Ibiza 6J FR SC 2.0 TDI, ... Electrical Systems, Vehicle Electronics, Multimedia
