T6 TDI Water Pump: Should You Replace It?
Post18-10-2026, 10:41    Subject: T6 TDI Water Pump: Should You Replace It? Quote
At 210,000 km, the timing belt needs to be replaced on my 2.0 TDI engine with 110 kW.
What about the water pump? Should it really be replaced, and what are the experiences with that?
Is there anything specific I should watch out for with this engine?
Thank you, best regards, Rainer.
Translated on 18-10-2026, 10:42.
chli1976
dieselschrauber likes this.
Post18-10-2026, 11:44    Subject: T6 TDI Water Pump: Should You Replace It? Quote
You absolutely have to participate; the water pump is usually the component that fails most often.
VCDS
Translated on 18-10-2026, 11:44.
Post18-10-2026, 12:47    Subject: T6 TDI Water Pump: Should You Replace It? Quote
Okay, thanks for your assessment!
icon_biggrin.gif I've never had one break on me - possibly because I've always ordered them together.
Translated on 18-10-2026, 12:47.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
Post18-10-2026, 14:53    Subject: T6 TDI Water Pump: Should You Replace It? Quote
Hello Rainer,
Based on my experience, it's relatively common for water pumps to get stuck and remain permanently open. This prevents the engine from reaching its proper operating temperature.
Otherwise, it is important to ensure the tensioner is installed correctly. VW uses two different versions of the tensioner for this engine. Therefore, some manufacturers include two different tensioners in the timing belt kit with the water pump to ensure that both versions are covered.
VW uses tensioner pulleys from the manufacturers Litens and Gates, which are different. Contitech has publicly available information about these.
I therefore agree with Chli1976: The water pump definitely needs to be replaced.
Michael.
Translated on 18-10-2026, 14:55.
No new posts Intercooler for 110kW TDI PD Engine Diesel Engine Technology
No new posts Oil pressure issues with TDI 110kW?? Diesel Engine Technology
No new posts Turbo Pressure: What's the Ideal Setting? Diesel Engine Technology
No new posts How quickly should a 1Z warm up? Diesel Engine Technology
