Golf 1 won't accelerate
sebo82
Post18-11-2026, 13:54    Subject: Golf 1 won't accelerate Quote
I bought a Volkswagen Golf 1, manufactured in 1981. The engine code is CR.
I replaced the timing belt, adjusted the fuel injection, replaced the fuel filter, and changed the engine oil and filter.
The engine starts when I pull the choke. It then runs at a slightly higher RPM.
If I push the choke lever back in after a while, the engine speed doesn't decrease.
When I press the accelerator pedal, nothing happens.
Perhaps someone can help me.
Thank you.
Translated on 18-11-2026, 13:55.
Karma: +1353 / -0   Thank you, like it!
dieselschrauber likes this.
Post18-11-2026, 14:53    Subject: Golf 1 won't accelerate Quote
a near-vintage, early-model diesel engine. Before that, there was the 50 horsepower model.
Was the engine running normally before your service?
Are the transparent lines connecting to and from the ESP bubble-free during operation?
Translated on 18-11-2026, 15:00.
sebo82
Post18-11-2026, 15:20    Subject: Golf 1 won't accelerate Quote
Hello Herbert.
Thank you for the message.
Before my service, the vehicle had been sitting in a garage for 20 days.
The hoses are bubble-free. The engine has been running for approximately 10 minutes at a slightly elevated idle speed.
It also starts up again immediately.
It only works if you include the gas intake; otherwise, it's non-functional.
Translated on 18-11-2026, 15:21.
Post18-11-2026, 15:30    Subject: Golf 1 won't accelerate Quote
sebo82 wrote:
.....Before my service, the vehicle
had been standing in a garage for 20 years. } 20 years? Then the ESP is probably likely to be hardened inside. You can hope that the fresh diesel will dissolve it, but I don't think so. }
Find the instructions online, unpack it, clean it, and assemble it correctly.
Translated on 18-11-2026, 15:31.
sebo82
Post18-11-2026, 15:36    Subject: Golf 1 won't accelerate Quote
I haven't been able to find any instructions for it yet. The VW dealer laughed when I asked about it.
Translated on 18-11-2026, 15:36.
Post18-11-2026, 16:04    Subject: Golf 1 won't accelerate Quote
Herbert wrote:
.....Find the instructions online, open the package, clean the parts, and assemble them correctly without misalignment...
There are enough posts on that topic. VW only knows about replacing the pump.
Translated on 18-11-2026, 16:04.
Karma: +592 / -0   Thank you, like it!
Post18-11-2026, 17:47    Subject: Golf 1 won't accelerate Quote
Hi!
Na, das war mein erster VW. VP Diesel.
It is normal for the idle speed to increase slightly when the choke, cold start valve, or accelerator pump is activated.
The engine also makes a bit more noise.
However, if you push the KSB (presumably a component) back in, it should return to a normal idle state.
Yes, it's possible that something is stuck or clogged in the fuel injection pump.
I don't know how long the biofuel content in diesel has been around.
I once had a small truck, and whenever it sat for a long time, I always had problems with it.
I would wait and see for now; maybe it will resolve itself eventually.
Perhaps you could gently tap the ESP unit while the engine is running.
What other problems were there with the engines?
The timing gear on the fuel injection pump sometimes had excessive play.
You can check that out. But you really have to press hard to notice it.
As a result, the timing belt can become misaligned, especially when it has been recently tightened.
It could then tear, or it could be abraded by the edges of the tension roller.
Take a look at that; if the timing belt pulley has any play on your ESP system, you'll need a different one anyway.
Translated on 18-11-2026, 20:20.
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW AAZ: No Acceleration Below 1/3 Throttle Diesel Engine Technology
No new posts TDI Engine: Won't Accept Fuel? Troubleshooting Diesel Engine Technology
No new posts 1.9 TDI: Intermittent Engine Misfire - Causes & Fixes On-Board Diagnostics (OBD)
No new posts Engine Won't Accelerate? Troubleshooting Guide. Diesel Engine Technology
