Passat 3B: Broken Control Arms - Repair Guide
Alchard
Post10-06-2003, 21:07    Subject: Passat 3B: Broken Control Arms - Repair Guide Quote
I have a 1998 Passat (AFN rules!!! icon_razz.gif) with worn ball joints, 'on the right front, both top and bottom' icon_confused.gif.
'Since the outer edge of the front right tire is more worn, my question is: can worn control arms affect the alignment? Of course, I know I should replace them... Does anyone have a good tip on where I can get them at the most affordable price? VAG wants to charge me 900 EUR (!!!) for three control arms including installation...'
Does the support bracket really need to be removed, or is there another way to do it?
'I definitely got it covered under warranty when it was at 148,000 km, but unfortunately, it's no longer covered now that it's at 168,000 km.'
alchard
Translated on 01-09-2026, 4:15.
verdiener
Post25-06-2003, 18:22    Subject: Passat 3B: Broken Control Arms - Repair Guide Quote
Well, I'm not aware of any 'trick' to it. I've also dealt with this topic many times!
Since the support bracket needs to be removed, this results in long working times, including the necessary wheel alignment.
If I were you, I would have it done by an independent workshop. The labor costs are only half as much there. You can also find high-quality control arms for significantly cheaper on the open market compared to what VW charges.
However, only VW can perform the wheel alignment correctly (due to the complex suspension system).
Translated on 01-09-2026, 4:17.
Alchard
Post25-06-2003, 20:56    Subject: Passat 3B: Broken Control Arms - Repair Guide Quote
Hello and thank you for the information...
I replaced the control arms myself in my garage... I drilled a 10cm long screw by hand... it took 3 hours icon_redface.gif icon_redface.gif ... but I did it! Including removing the stabilizer bar. The alignment doesn't need to be adjusted, as long as the screws on the tie rod ends are not touched.
The catch was icon_eek.gif: 4 days later, the CV joint boot failed. icon_evil.gif So, I had to loosen the control arms again. icon_rolleyes.gif ... but I had applied copper grease to everything, so there were no problems removing the driveshaft. It took about half an hour, this time using a lift. ...
alchard
Translated on 01-09-2026, 4:18.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Tie Rods: Steering Linkages & Components Transmission, Chassis, Body & Interior
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
