Diagnosis Interface
mozz
Post24-05-2002, 13:17    Subject: Diagnosis Interface Quote
Hello!
Hey, where can I actually get the connector for the diagnostic interface? Also, does it also fit on the serial port?
Hello everyone! The forum is really amazing!!
Rudi
Post24-05-2002, 14:13    Subject: Diagnosis Interface Quote
To connect the serial port of a PC to the diagnostic port, you first need an adapter (Jeff Noxon, the link should be on the left side).
I am also looking for an (affordable) alternative to the 16-pin diagnostic socket in the car icon_smile.gif
I believe it's the most efficient solution to tap into 3-4 lines and connect them to a sub-D connector that matches the pin configuration of the adapter.
No new posts Diagnose Adapter Eigenbau - On Board Diagnose - DoItYourself Troubleshooting & Guides
No new posts Diagnose von Eberspächer Standheizungen Troubleshooting & Guides
No new posts VCDS: On-Board-Diagnose an VAG Fahrzeugen Troubleshooting & Guides
No new posts Golf IV/ Audi A4 Diagnose Schnittstelle On-Board Diagnostics (OBD)
No new posts Schnittstelle zur Ansteuerung der Zentralverriegeung Electrical Systems, Vehicle Electronics, Multimedia
No new posts VAG-Com and Notebook without a Serial Port Diesel Engine Technology
No new posts passat tdi, mkb 1Z, has a OBD2 interface On-Board Diagnostics (OBD)
