Air Filter Replacement VW Passat 35i TDI 1Z
WarLord
Post11-07-2003, 18:38    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
Could someone provide me with a simple guide on how to replace the air filter in a Passat 35i with a 1Z TDI engine? I'm not sure how to do it correctly because the A/C pipes run over the air filter housing. Also, does anyone know where the air intake is located (the exact position), and if there's a coarse filter grille there as well?
Best regards, WarLord.
Translated on 05-08-2026, 8:55.
DocSnydor
Post12-07-2003, 8:29    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
Unfortunately (or perhaps fortunately), my Passat doesn't have air conditioning. When I open the hood, I can access four brackets and have the air filter in my hand. Normally, it sucks in air from the right fender using a kind of 'trumpet,' where the space is structurally separated from the engine compartment...
I can't answer your question about the climate.
David.
Translated on 05-08-2026, 8:57.
WarLord
Post12-07-2003, 19:05    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
I can see the brackets, but I'm having trouble reaching the ones at the back. I'm also not sure how to remove the cover, or if it can be slid to the side.
DocSnydor
Post13-07-2003, 13:14    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
Unclip the 4 clasps, and then you can remove the lid just like from a Rama container... icon_wink.gif
You still need to adjust it a bit, as it sometimes gets stuck under the bridge of the fender.
Translated on 05-08-2026, 8:58.
WarLord
Post13-07-2003, 13:33    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
Do I need to detach the hose connected to the mass airflow sensor somehow, or can I simply fold it away along with everything else?
Translated on 05-08-2026, 8:59.
DocSnydor
Post13-07-2003, 17:10    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
Of course, you can fold the Schaluch away; that's why the flexible piece is built in.
Isn't that even stated in the instruction manual?!
WarLord
Post13-07-2003, 18:44    Subject: Air Filter Replacement VW Passat 35i TDI 1Z Quote
I thought it was there, but I couldn't find it yesterday. Sorry for the silly questions, but I just don't want to break anything. There isn't a pre-filter in the front of the Passat, right? I read something about a pre-filter for leaves and didn't see that on my car.
Translated on 05-08-2026, 9:00.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Change Air Filter? [DIY Guide] Diesel Engine Technology
No new posts Replacing shock absorbers on a Passat 35i **Parts Requir... Transmission, Chassis, Body & Interior
No new posts Tie Rod Replacement Passat 35i Transmission, Chassis, Body & Interior
No new posts VW Passat Oil Pan Replacement: Lower Engine Mount Transmission, Chassis, Body & Interior
