davidshoes Blaumann
Joined: 06/10/2002 Posts: 155 Karma: +6 / -2 Location: Sachsen
04-07-2003, 14:38 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Hi, I've read a lot of posts about the Mass Air Flow sensor (MAF) from Pierburg, but I haven't found anything specific. Would the one from DC fit in an A4? Because mine is really broken, and Büchl or RAR don't have any in stock either. eBay is too risky for me (with MAF sensors). A new one costs around 270-300€. That's too expensive. Cleaning it didn't help. But I was told that the ones from the V6 TDI also fit and only measure about 10% more airflow. That shouldn't be a problem if everything else works. You just shouldn't give it full throttle in fifth gear at 1200 RPM  .
Does anyone have any ideas?
Translated on 21-10-2026, 17:50.
voss Blaumann
04-07-2003, 15:40 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Hello.
If, as you write, this is supposed to be for an AFN engine, then it must fit.
I recently bought a DC unit and installed it in my Passat (AFN).
After a minor adjustment to the connector (a slightly different locking mechanism), everything is working properly again, and the car is pulling normally.
Bestl No. A 6110940048 from a friendly DC dealer, price: 72? including.
Rafael.
Translated on 21-10-2026, 17:51.
davidshoes Blaumann
04-07-2003, 16:23 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Okay, I just placed the order. I'll let you know if everything works out. And regarding the locking mechanism, it shouldn't be a problem for a skilled tradesperson.
Translated on 21-10-2026, 17:52.
davidshoes Blaumann
07-07-2003, 20:18 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Translated on 21-10-2026, 17:53.
07-07-2003, 20:49 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
davidshoes wrote: | | Hey, I got the new LMM (lambda sensor) from DC today and installed it. I drilled two small holes in the connector so that the other pins can click in, and the A4 is a diesel again. It cost €71.49, not €300 like it would have from VAG. |
Hello.
I still don't quite understand it.
I have the old Pierburg unit "as a whole piece," meaning it's not the type with a small insert that can be removed. The VAG part number is 074 906 461.
The new LMMs for the VP-TDIs probably have the VAG part number 028906461.
Can only these be replaced with the DC components?
Does DC only provide the small insert, about the size of a thumb, which is secured with Torx screws, or do they provide the entire tube including the insert?
. . . so that the tube can ultimately be replaced "in one piece" with a Pierburg unit  .
Translated on 21-10-2026, 17:55.
Profile PM Garage |
KombiBlue Blaumann
Joined: 04/18/2003 Posts: 76 Karma: +7 / -0 Location: D-48165 Münster
07-07-2003, 21:43 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Hello, at DC, there's only the small "insert". If you want to replace it with your "complete" LMM, you could ask your local dealer for a defective LMM. Then, you can take the "tube" from that and install the DC LMM!
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 21-10-2026, 17:56.
Andy Guest
08-07-2003, 1:46 Subject: MAF Sensor 1.9 TDI AFN - Pierburg? |
Hello, at DC, there's only the small 'insert'. If you want to replace it with your 'complete' LMM, you could ask your local dealer for a defective LMM. Then, you can take the 'tube' from it and install the DC LMM!
...with the small but significant drawback that the connector then no longer fits. The old Pierburg unit, which is a single piece, has a completely different connector than the one available from DC for installation in the pipe.
Andy.
Translated on 21-10-2026, 17:57.
