hueso Guest
28-07-2003, 11:56 Subject: Turbocharger removed and reinstalled? |
I have an A3 TDI (ASV) and I want to send my turbocharger in for repair. To do this, I need to remove and reinstall it. What is the best way to do this? What is the torque on the screws? Is there a lot of oil and coolant leaking from the lines? Is there a repair guide - I couldn't find a repair guide specifically for turbochargers when I checked with Erwin.
Best regards, Hüso
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
28-07-2003, 12:23 Subject: Turbocharger removed and reinstalled? |
What year model is it? Tschüss
Michael II
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
28-07-2003, 12:36 Subject: Re: Removing and Reinstalling Turbocharger?
{QUESTION}
{REQUEST}
{STATUS}
{DATE}
{TIME}
{LOCATION}
{CONTACT_PERSON}
{PHONE_NUMBER}
{EMAIL_ADDRESS}
{NOTES} |
hueso wrote: | regarding Erwin, I couldn't find a direct repair guide for the turbocharger.
Hi Hüso,
that is usually included in "motor mechanics". ____________
Kein Auto mehr!
haehnlein Schrauber
28-07-2003, 12:37 Subject: Re: Removing and Reinstalling Turbocharger?
{QUESTION}
{REQUEST}
{STATUS}
{DATE}
{TIME}
{LOCATION}
{CONTACT_PERSON}
{PHONE_NUMBER}
{EMAIL_ADDRESS}
{NOTES} |
hueso wrote: | | Are there a lot of leaks of oil and coolant from the lines? |
There are no coolant connections in this area. A few drops are leaking from the oil supply and return lines. ____________
Kein Auto mehr!
hueso Guest
28-07-2003, 13:24 Subject: Turbocharger removed and reinstalled? |
It is for the 2000 model year.
As it sounds on the Audi website, you need to register first, and I'm not sure if I'll have to pay regularly. Does anyone perhaps have the repair manual and would like to sell it to me?
Best regards, Hüso
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
30-07-2003, 9:57 Subject: Turbocharger removed and reinstalled? |
I know from my experience that a lifting platform is very useful, as it makes it much more difficult to disconnect and reconnect the lower oil line otherwise.
Actually, I didn't really get much oil coming out of the lines either.
Otherwise, I haven't encountered any particular difficulties.
Greetings
Thomas -----------------------------------------------------
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
hueso Guest
30-07-2003, 14:50 Subject: Turbocharger removed and reinstalled? |
Sure, here are the steps and torque values for the screws:
1. Attach the front and rear axles to the frame using the provided bolts and washers. Make sure the axles are properly aligned and secured.
2. Attach the front and rear wheels to the axles using the provided bolts and washers. Make sure the wheels are properly aligned and secured.
3. Attach the handlebars to the frame using the provided bolts and washers. Make sure the handlebars are properly aligned and secured.
4. Attach the seat to the frame using the provided bolts and washers. Make sure the seat is properly aligned and secured.
5. Attach the pedals to the front and rear axles using the provided bolts and washers. Make sure the pedals are properly aligned and secured.
6. Attach the brake levers to the handlebars using the provided bolts and washers. Make sure the brake levers are properly aligned and secured.
7. Attach the brake cables to the brake levers and the brakes using the provided bolts and washers. Make sure the brake cables are properly aligned and secured.
8. Attach the chain to the front and rear sprockets using the provided bolts and washers. Make sure the chain is properly aligned and secured.
9. Attach the kickstand to the frame using the provided bolts
Best regards, Hüso
