TDI Power Loss: Troubleshooting & Solutions
torsten1981
Post27-07-2003, 0:59    Subject: TDI Power Loss: Troubleshooting & Solutions Quote
Good evening.
Recently, I haven't been able to reach the top speed of approximately 190 km/h with my 110 HP TDI. icon_smile.gif While I also think that's a bit low, as other drivers with 110 HP TDIs report speeds of almost 200 km/h on their odometers, the car is only registered for a top speed of 193 km/h. Currently, the maximum speed is around 170-180 km/h. } I think this can only be due to a loss of power in the engine. } For example, if I fully accelerate in 2nd gear, I feel (!!) that the power drops slightly around 1900 RPM. } However, that might be my imagination.
I once measured the voltage at the mass airflow sensor (MAF). It's at a maximum of 3.8 volts in the second gear at full throttle. As far as I know, it should be around 4.5 volts.
Can I conclude that the problem is caused by a faulty mass airflow sensor, or are there other possible causes?
I would be very grateful for a few tips.
Best regards, Torsten.
Translated on 04-10-2026, 20:27.
Post27-07-2003, 9:08    Subject: TDI Power Loss: Troubleshooting & Solutions Quote
torsten1981 wrote:
I once measured the voltage at the mass airflow sensor. It's at a maximum of 3.8 volts in second gear at full throttle. As far as I know, it should be around 4.5 volts.
Can I conclude that the problem is a faulty mass airflow sensor, or are there other possibilities to consider?
Hi Torsten,
Yes, other possibilities are being considered.
Which LMM (lambda measuring module) do you have, Pierburg or Bosch?
Translated on 04-10-2026, 20:29.
torsten1981
Post27-07-2003, 15:08    Subject: TDI Power Loss: Troubleshooting & Solutions Quote
I have a Bosch mass airflow sensor. I think I'm going to test what happens if I try to 'trick' the electronics with a diode.
I once had some damage to the right side of the car. That's where the intercooler is located. Could the intercooler, or a sensor nearby, have been affected?
Is there any other potential source of error that I could easily identify?
Thank you.
Torsten.
Translated on 04-10-2026, 20:30.
Post27-07-2003, 16:30    Subject: TDI Power Loss: Troubleshooting & Solutions Quote
...and is there a source of information that would allow one to relatively easily determine which model of car you are driving?
Translated on 04-10-2026, 20:31.
torsten1981
Post27-07-2003, 17:45    Subject: TDI Power Loss: Troubleshooting & Solutions Quote
Oops... I'm, more or less, the proud owner of a Seat Leon. The engine is a VW design. It might have been clever to mention that earlier. Sorry.
Translated on 04-10-2026, 20:32.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Intermittent Power Loss: Audi A4 Troubleshooting Upload
No new posts TDI (110 hp) engine failure! Diesel Engine Technology
No new posts 1Z to AFN Engine Swap: 110HP Upgrade Diesel Engine Technology
No new posts Ibiza TDI: Standheizung für 110PS Modelle Diesel Engine Technology
