What could be causing the loading pressure issue?
mhernach
Post01-08-2003, 11:25    Subject: What could be causing the loading pressure issue? Quote
http://www.duw.de/DuWCarbox/ShowImage.aspx?ID=2153
Unfortunately, it's much too small... I can also send you the Excel file... Is this normal?
it's about ensuring that the target and actual charging pressure match...
where can I insert an image that is larger, or an xls file would be even better.
Best regards, Mike
Post01-08-2003, 11:31    Subject: What could be causing the loading pressure issue? Quote
Possible causes:
- Engine misfire, see fault codes
- Insufficient fuel supply to the engine
- Loading pressure control malfunction
- Turbocharger malfunction.
See Ulf's technical article on troubleshooting.
Hello, Rainer
TDI Kraft ohne Ende
Post01-08-2003, 19:12    Subject: What could be causing the loading pressure issue? Quote
Hello
Take a look below
'Loading pressure development and air mass'
There is a similar problem.
Please send me the Excel file.
Also, there were also discrepancies between the planned and actual figures.
Best regards, Ralph
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High Boost Issues: What Else Could It Be? Diesel Engine Technology
No new posts Turbocharger: 255 HP - Is That Possible? Diesel Engine Technology
No new posts Smallest Diesel Engine: How Tiny Can It Be? Diesel Engine Technology
No new posts 00575 - Intake manifold pressure: What could it be? On-Board Diagnostics (OBD)
