Strange noise when starting?
Mario
Post24-05-2002, 18:02    Subject: Strange noise when starting? Quote
For quite some time now, I've been hearing a strange, screeching noise from my Golf III TDI (manufactured in 1995) when starting it!
Once or twice a week, and always the same noise (has been the same for over 2 years)
Temperature and humidity have no effect (the scratching sound remains constant).
No loose belt, it sounds like a bad bearing (maybe the starter)!
It's only audible for a very short time (1 second) after the start!
My KM Stand: 135,000!
A tip would be helpful on how to contain the error!
Bye.
Mario
Post24-05-2002, 19:49    Subject: I know too . . . Quote
. . . but it only occurs for me every few months.
I'm currently content with the idea that the occasional condensation on the LiMa belt could cause it to slip and squeak, until it evaporates due to friction.
Post25-05-2002, 1:01    Subject: Squeaking-Scratching sound during starting Quote
My tenant also has a G3 Lim 1Z and he had the same problem - starter failed - problem solved.
---- and a whole lot of money....
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Motorruckeln beim Starten und Ausmachen Diesel Engine Technology
No new posts Passat 3C - Starting problems with the engine (1.4 TSI, C... Gasoline Engine Technology
No new posts gelbe Vorglühlampe geht beim TDI-Starten nicht aus Diesel Engine Technology
No new posts Starting problems in warmer temperatures + solution!! Diesel Engine Technology
