Performance Loss Above 130 km/h (AJM)
mgolz
Post27-08-2003, 7:30    Subject: Performance Loss Above 130 km/h (AJM) Quote
I am newly registered, but I have also already read all the threads on this topic, unfortunately, none of it has helped me. icon_sad.gif
It all started with an engine failure: a broken valve, damage to the engine block, cylinder head, turbocharger component, and valves, with metal shavings in the turbocharger...
'After that, I ordered an AJM engine, including the turbocharger, from a car dismantler. The dismantler said it came from an Audi, but that the engines were the same, although, the engine's wiring harness was definitely different.'
The engine, including the turbo, has been replaced and it runs, but the power cuts out after 130 km/h.
Previous repair attempts:
- Solenoid valve replaced.
- LMM replaced.
- Pressure sensor replaced.
- Installed the charger box from the old turbo.
'Yesterday, I installed a boost pressure gauge and did some test runs. The conclusion is that the power cuts out when the boost pressure drops below 2 bar; I suspect the electronics are going into a failsafe mode. The error code in the diagnostic memory says 'Boost pressure control difference'.'
Does anyone have any suggestions for what else I could do?
A friend of mine mentioned that it might be possible to adjust the travel of the VTG (Variable Transverse Gap) mechanism.
Translated on 09-10-2026, 16:05.
Thomas K
Post27-08-2003, 7:46    Subject: AJM: Power Loss Above 130 km/h Quote
mgolz wrote:
The error code in the fault memory reads "Boost pressure regulation difference".
The error message "boost pressure regulation difference" usually indicates a stuck VTG (variable turbine geometry). How to fix a stuck VTG has been explained in many posts.
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Translated on 09-10-2026, 16:07.
mgolz
Post27-08-2003, 7:53    Subject: Performance Loss Above 130 km/h (AJM) Quote
Using a diagnostic device, we were able to move the part icon_wink.gif.
Translated on 09-10-2026, 16:08.
Thomas K
Post27-08-2003, 8:13    Subject: Performance Loss Above 130 km/h (AJM) Quote
It might be. A stuck VTG (Variable Turbine Geometry) simply means that the turbine blades are harder to move than usual. At increasing speeds, the blades open too slowly, and then the emergency mode is activated. In emergency mode, the blades open, and the engine delivers less power; the maximum speed is usually around 130-140 km/h. So, remove the deposits from the blades.
Gruß Thomas
mgolz
Post27-08-2003, 8:15    Subject: Performance Loss Above 130 km/h (AJM) Quote
'The 'new' engine has only 8,000 kilometers on it, and it's already supposed to have deposits?'
Should I drain the oil when I remove the turbo?
or doesn't much come out icon_question.gif?
Translated on 09-10-2026, 16:09.
Michael II
Post27-08-2003, 8:24    Subject: Performance Loss Above 130 km/h (AJM) Quote
Before you start disassembling everything, I would recommend doing a measurement run.
Here in the forum, you'll find information on how to do it and which data is important.
The values might help to narrow down the source of the error.
PS: Have you ruled out all possible causes of the discrepancy in the rules (see knowledge base)?
Tschüss
Michael II
Translated on 09-10-2026, 16:10.
mgolz
Post27-08-2003, 8:53    Subject: Performance Loss Above 130 km/h (AJM) Quote
all the possible errors that are listed here:
Can I rule it out?
I haven't found much information about that measurement trip.
How should I drive? I currently only have the LDA available. icon_redface.gif
Translated on 09-10-2026, 16:11.
Thomas K
Post27-08-2003, 9:13    Subject: Performance Loss Above 130 km/h (AJM) Quote
mgolz wrote:
The "new" engine has only 8000 km on it, and is supposed to already have deposits
I also bought a vehicle with approximately 5,000 km on the odometer, about 1.25 years old, directly from VW in Wolfsburg. It seems they only drove it in the city and on the factory grounds. In any case, I also had a stuck VTG (Variable Turbine Geometry). The error code in the diagnostic memory was the same as yours.
Gruß Thomas
Translated on 09-10-2026, 16:12.
Michael II
Post27-08-2003, 10:00    Subject: Performance Loss Above 130 km/h (AJM) Quote
Hello mgolz,
You can find everything about the measurement run under "Technical Articles" => "Tips & Tricks" => "Target Data".
Tschüss
Michael II
mgolz
Post27-08-2003, 10:41    Subject: Performance Loss Above 130 km/h (AJM) Quote
@Michael II
That's fine, but I only have an LDA and no VAG tester available.
The test run with the workshop previously showed a boost pressure (at full load) of approximately 2500 mbar.
Unfortunately, I don't know any more than that.
and how does this now relate to the turbocharger replacement? should I drain the oil beforehand icon_question.gif?
Translated on 09-10-2026, 16:13.
mgolz
Post27-08-2003, 18:10    Subject: Performance Loss Above 130 km/h (AJM) Quote
Well, if you don't do everything yourself.
I found the bug; a small cause, a big effect.
My friend said that he checked all the hoses carefully.
and what do I find? a reversed connection of the hoses on the VTG pressure regulating valve!!!
but still: if I want to remove the turbo, should I drain the oil icon_question.gif?
Translated on 09-10-2026, 16:14.
Frankenchris
Post27-08-2003, 18:56    Subject: Performance Loss Above 130 km/h (AJM) Quote
Hello mgolz,
'Hey, how fast was your car running with the hoses swapped?'
Translated on 09-10-2026, 16:15.
mgolz
Post27-08-2003, 20:38    Subject: Performance Loss Above 130 km/h (AJM) Quote
At 130 km/h, it went into emergency mode, but that's not surprising with a boost pressure of 2 bar.
Thank you to everyone:D
mhernach
Post29-08-2003, 6:13    Subject: Performance Loss Above 130 km/h (AJM) Quote
At 130 km/h, it went into emergency mode, but that's not surprising with 2 bar of boost pressure.
Hi... so, with a boost pressure of 2 bar, you're doing pretty well. 2.5 bar would mean you have 1.5 bar of overpressure (which probably wouldn't be sustainable for the engine for very long). I also had that error message before, and I ended up replacing the boost pressure valve, and it went back to normal.
Best regards, Mike.
Translated on 09-10-2026, 16:16.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsverlust AUY 85 KW Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts Power loss 2.0 TDI 125 kW BMN Diesel Engine Technology
