LMM: Murphy's Law of Special Tools
Post19-08-2003, 19:09    Subject: LMM: Murphy's Law of Special Tools Quote
"It won't fit."
This happened today at our ALH-Ibiza location.
Apparently, the Mass Air Flow sensor (MAF sensor) from Bosch has failed on a colleague's car (a 110 HP Octavia), and I was actually planning to remove the sensor tomorrow to try cleaning it.
Earlier, I took measurements on the Ibiza (whose lambda sensor is still OK) to determine which Torx size fits, and it turns out: From the outer diameter, it appears to be a 15, but the nipple on the screw is thicker than the hole in the tool icon_evil.gif.
And it does this with 2 different tools: a Torx screwdriver and a bit insert!!
"How do you remove the LMM (Laser Material Processing) inserts from the tube when, for example, you're installing a DC (Direct Current) insert?"
Translated on 22-10-2026, 16:41.
KombiBlue
Post19-08-2003, 19:44    Subject: LMM: Murphy's Law of Special Tools Quote
Hi, my LMM (likely referring to a Lambda sensor or similar component) came off with a Torx 20 bit!
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 22-10-2026, 16:42.
Post19-08-2003, 19:51    Subject: LMM: Murphy's Law of Special Tools Quote
KombiBlue wrote:
Hello, my LMM came off with a 20 Torx key!
Thank you, I just tried it myself with a size 20, and it fit (it looked too thick to me at first) icon_redface.gif.
Well, then I will include the size in the LMM technical article - if it works for you and for me, that will probably be the standard size.
Translated on 22-10-2026, 16:43.
Helmut
Post19-08-2003, 20:10    Subject: LMM Allen Screws: How to Open Them Quote
Hello Ulf,
I have a set of security bits from Proxxon, and those work. It also includes other great items, such as three-wing screwdriver bits and slotted screwdrivers with a hollow shaft.
Very expensive, around 40 euros. There are also cheaper, generic options available at hardware stores.
Helmut.
EDIT:
Problem seems to be solved! I haven't tried it with anything else.
Translated on 22-10-2026, 16:44.
Sound Lupo 3L
Post19-08-2003, 20:28    Subject: LMM: Murphy's Law of Special Tools Quote
hi,
I simply broke off the pin in the middle using a small flathead screwdriver.
greetings
Translated on 22-10-2026, 16:45.
Post20-08-2003, 6:25    Subject: LMM: How to Open Allen Head Screws Quote
Helmut wrote:
Hello Ulf,
I have a set of security bits from Proxxon, and those work. It also includes other great items, such as three-way slotted bits and slotted screwdrivers with a hollow shaft.
"However, you can find similar tools from well-known brands at a much lower price. It's just that the hardware store charges extremely high prices!"
http://www.welt-der-werkzeuge.de/skluee/cgi-bin/his-webshop.pl?f=NR&c=f2331&t=temartic
In that shop (mentioned above), there used to be a set of bits containing all sorts of specialized keys (triangular, three-slot, Torx with hole, Allen with hole, etc.) for just 14 euros.
Translated on 22-10-2026, 16:46.
joergs
Post20-08-2003, 7:04    Subject: LMM: Murphy's Law of Special Tools Quote
Hi there,
'I recently bought a no-name toolset from Wolfcraft at Globus. It contains all sorts of specialized bits and cost €4.95. Of course, the quality and durability of the bits can be debated. However, I think it's sufficient for the frequency and type of tasks I need to do.'
Translated on 22-10-2026, 16:47.
Georg_G
2012 Volkswagen Golf
Post20-08-2003, 9:00    Subject: LMM: Murphy's Law of Special Tools Quote
A good source for tools is also the online shop of Westfalia. They have a 108-piece set with pretty much all the unusual and less common safety bits for just 20 pence.
Best regards, Georg.
Translated on 22-10-2026, 16:48.
Post20-08-2003, 9:32    Subject: LMM: Murphy's Law of Special Tools Quote
Georg_G wrote:
There's also a 108-piece set with pretty much all the cool and less common safety bits for 20 pence.
That's exactly the part I bought for 14 euros.
robertf
Post20-08-2003, 13:04    Subject: LMM: Murphy's Law of Special Tools Quote
A few days ago, I encountered a new variant (manufacture date 5/03): Instead of a 20mm Torx, it has a slightly larger 5-point star with a pin in the center. Even the complete Westfalia box with all the possible security bits failed, I had to mill a groove to be able to screw on those darn icon_evil.gif parts. Perhaps VW has now reacted to the DIY hardware store enthusiasts (?).
Robert.
Translated on 22-10-2026, 16:49.
Reiner_mit_ei
Post26-08-2003, 7:02    Subject: LMM: Murphy's Law of Special Tools Quote
Hello robertf,
Not a 20mm Torx, but a slightly larger 5-point star with a pin in the center.
You can find the corresponding socket wrenches ('nuts') at Klann. They cost 11.90 euros.
You might also want to check with Snap-On sometimes; they often have unusual items. I'm not sure about Hazet right now.
Pure.
Translated on 22-10-2026, 16:50.
Dan.jel
Post26-08-2003, 8:15    Subject: LMM: Murphy's Law of Special Tools Quote
I can confirm that, as it's used in models like the 110kW TDI.
I removed the two screws using a small, fine-toothed pipe wrench.
I then replaced the screws with T20 Torx screws so that I wouldn't have any problems when replacing them in the future.
VW has been using those screws for at least 2 years! That means the mass airflow sensor (MAF sensor) is probably that old.
Translated on 22-10-2026, 16:51.
Crissi
Post29-08-2003, 8:31    Subject: Torx Screws: 5-Star for Linear Motors Quote
Does anyone happen to know the required size for the aforementioned screws?
http://www.hazet.de/deutsch/produktinfo/pdf/2225_7h_1.pdf
Translated on 22-10-2026, 16:52.
Dan.jel
Post29-08-2003, 8:57    Subject: LMM: Murphy's Law of Special Tools Quote
I'd guess around 20 or 25, but how can we measure that more precisely?
No new posts Looking for specialized tools for camshaft replacement. Diesel Engine Technology
No new posts Rear Axle Bearing for VW Golf III Transmission, Chassis, Body & Interior
