Engine Failure: AFN Fuel Cut-Off Problem
nobody2000
Post15-05-2004, 12:22    Subject: Engine Failure: AFN Fuel Cut-Off Problem Quote
Hello everyone.
I've already been searching, but I haven't found anything that's quite right for me.
I hope you can help me:
When I release the accelerator pedal in my car, it seems like the engine is about to stall.
'Then, when I accelerate again, there's a lot of smoke initially, and it doesn't respond to the throttle. After about 1-2 seconds, it seems to kick back in (?) and then it runs normally until I have to let off the gas completely again.'
I hope you can help me.
Best regards.
Christian.
BTW.
Data is:
Engine swap: 110 horsepower AFN engine from a Sharan, installed in a VW Bus T3.
Translated on 11-10-2026, 23:14.
Post15-05-2004, 15:42    Subject: AFN Fails When Turning Off Gas Quote
nobody2000 wrote:
When I release the accelerator pedal in my AFN, the engine seems to stall.
If I then accelerate again, it initially produces a lot of smoke and it doesn't respond to the throttle. After about 1-2 seconds, it seems to catch again (?) and then it runs normally until I have to completely release the throttle.
Hi Christian,
"Grab your VAGCOM and log the measuring block 1 (including the injection quantity and the rail pressure), as it seems most likely to be a problem with the fuel pump."
In addition, please check the injection system (are there any bubbles in the transparent tubing? Is the filter clogged?).
Is the engine's performance within the normal range?
Translated on 11-10-2026, 23:16.
nobody2000
Post15-05-2004, 17:27    Subject: Engine Failure: AFN Fuel Cut-Off Problem Quote
Hi Ulf,
Thank you for your response.
Unfortunately, I can't provide you with VAG-Com today, but I might be able to borrow it tomorrow.
I checked the injection system, but everything seems normal; there are no air bubbles or anything like that.
I could still replace the fuel filter, but since I'm not experiencing any loss of power while driving, I'm going to rule it out for now. However, I'm open to being proven wrong.
I also have another problem, namely that it's very difficult, or even impossible, for the car to start when it's cold. And when it does eventually start, there's a cloud of smoke that I don't want to subject my neighbors to too often icon_smile.gif.
Warm, it starts without any problems, so I blamed the glow plugs, but I just replaced them, and it made no difference icon_sad.gif.
Perhaps it's all connected. I'm hoping for more suggestions.
Christian.
Translated on 11-10-2026, 23:18.
PrivatBereich
Post17-05-2004, 9:25    Subject: Engine Failure: AFN Fuel Cut-Off Problem Quote
When it comes to cold start problems, the first things that come to mind are the temperature sensor and the fuel injection timing. --> Use the search function with the keywords 'cold start problem*'.
Check the temperature values and timing using VAG-COM.
Private.
Translated on 11-10-2026, 23:20.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI 130 PS (AVF): Noises When Releasing Gas Diesel Engine Technology
No new posts Engine Misfire: Short Noise When Releasing Gas Diesel Engine Technology
No new posts Boost behavior during throttle lift-off above 3000 RPM Diesel Engine Technology
No new posts Knocking sound from the engine area when releasing the ac... Diesel Engine Technology
