vagtuning Guest
09-03-2004, 18:34 Subject: A6 Goes into Safe Mode: Troubleshooting Guide |
A 2001 A6 V6 TDI with an AKE engine sometimes goes into limp mode for no apparent reason.
When accelerating fully, the engine control unit (ECU) demands 2300 mbar, but the turbocharger actually produces 2560 mbar.
And sometimes, you're driving with a lot of throttle, you briefly lift off the gas, and then the boost pressure drops, and the speed continues to decrease (it should be 2000 mbar, but it slowly drops from 1800 mbar down to 1100 mbar).
What would you guess? The car has already had its 3rd turbo installed, the last one being half a year ago... is it broken again?
Of course, the obligatory error message 'Charging pressure exceeds limit' is also missing.
Interestingly, he sometimes does it very frequently, while other times he doesn't do it for hours.
Translated on 30-10-2026, 1:53.
Gremlin Guest
09-03-2004, 19:19 Subject: A6 Goes into Safe Mode: Troubleshooting Guide |
Is N75 okay?
Is G71 okay?
Is G70 okay?
CU Gremlin.
Translated on 30-10-2026, 1:54.
vagtuning Guest
10-03-2004, 13:49 Subject: A6 Goes into Safe Mode: Troubleshooting Guide |
N75 is okay... (the basic on/off setting works, and the lever adjustment functions).
The LMM has also been newly received.
and the intake manifold pressure sensor is also okay according to the readings.
Translated on 30-10-2026, 1:55.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
10-03-2004, 14:50 Subject: A6 Goes into Safe Mode: Troubleshooting Guide |
Throwing away the N75 valve... how can you be sure that the valve won't occasionally get stuck?
Profile PM WWW Garage |
