Water Pump Replacement: Should You Replace It?
Go to page: 1, 2  Next
Yankee
Post21-09-2004, 15:22    Subject: Water Pump Replacement: Should You Replace It? Quote
hello,
I'm slowly approaching the 90,000 km mark, and I've already found an independent workshop that will do the timing belt replacement for a reasonable price.
I recently read online that there can be problems or leaks with the water pump during or shortly after replacement.
Should I also have the water pump replaced preventatively (+50)?
Who did this? / Who didn't do this?
Thank you & best regards from Vienna!
Translated on 16-08-2026, 21:36.
AndreasG
Post21-09-2004, 16:32    Subject: Water Pump Replacement: Should You Replace It? Quote
I also have a G IV AHF 04/98, and according to Volkswagen, the timing belt needs to be replaced every 60,000 km.
'were replaced because too many damages occurred due to broken belts. (Whether that's still the case now...'
voted ( icon_question.gif )
Okay, so my first service at 60,000 km was without a water pump replacement, and the second one (with a reinforced belt) included it.
This time, at 150,000 km, including the water pump replacement.
Translated on 16-08-2026, 21:38.
D. Kurz
Post21-09-2004, 20:20    Subject: Water Pump Replacement: Should You Replace It? Quote
Hello!
I can only repeat it: get rid of the water pump! Don't do it; the risk to your engine is too high! The water pump essentially consists of a ball bearing and an impeller. The ball bearing faces the same problems due to the new, tighter belt as the bearings in the tensioner pulleys, and you replace those, don't you? Just recently, I had another customer vehicle (okay, it was an Opel 2.0 OHC, but the water pump is driven by the timing belt, just like on a TDI) where the Opel dealership didn't replace the water pump during the first timing belt replacement. About 50,000 km later, the water pump seized, and the timing belt broke. However, it had an advantage over a TDI: as long as the engine speed is below 3000 rpm, the valves don't even come close to the pistons...
So, don't skimp on the wrong thing. The extra cost is only minimal, and you'll have to drain some of the broth anyway, as the balancing tank would be quite cumbersome.
Dominique.
Translated on 16-08-2026, 21:40.
joergs
Post21-09-2004, 20:59    Subject: Water Pump Replacement: Should You Replace It? Quote
If the water pump is driven by the timing chain, then get rid of it. What's the point if you have to start all over again after 20,000 km or 30,000 km?
From my own experience, I can tell you that the water pump replacement in my 96kW PD engine didn't last 90,000 km. Fortunately, it wasn't the bearing, but 'only' the impeller that failed. The replacement water pump cost me less than 50 euros. That small amount of money doesn't make a big difference.
Translated on 16-08-2026, 21:42.
Gremlin
Post21-09-2004, 21:36    Subject: Water Pump Replacement: Should You Replace It? Quote
same here.
When dealing with a TDI engine of this age, it's always best to replace the fuel pump as well.
The extra charge is disproportionate to the labor costs for a belt replacement.
Regarding the Opel mentioned earlier, it's still possible to achieve that within a half-hour timeframe. However, with the heavily modified TDI engine, it takes an incredibly long and frustrating amount of time.
CU Gremlin.
Translated on 16-08-2026, 21:43.
Yankee
Post21-09-2004, 21:58    Subject: Water Pump Replacement: Should You Replace It? Quote
Thank you for your numerous responses!
I'll then invest another $50 into a new VPN service.
Which bearing should I have replaced?
My mechanic didn't mention that!
The water pump replacement, including the screws (which need to be replaced), and the belt, will cost me €300.
Translated on 16-08-2026, 21:44.
Yankee
Post21-09-2004, 22:00    Subject: Water Pump Replacement: Should You Replace It? Quote
at 150,000 km this time, including the water pump.
Did you also have the bearings replaced? (If so, which ones?)
Translated on 16-08-2026, 21:46.
joergs
Post22-09-2004, 7:17    Subject: Water Pump Replacement: Should You Replace It? Quote
hi yankee
Replacing bearings on the WAPU (water pump unit) doesn't make sense. The pressed-on pulley or the pressed-on impeller would have to be removed, and that's where the problem likely starts.
You can get this part from VW as an exchange item. This means you return your old part and take a new one in its place. With a little ingenuity, you could also take the new part with you and deliver the old one later.
Translated on 16-08-2026, 21:47.
Yankee
Post22-09-2004, 7:29    Subject: Water Pump Replacement: Should You Replace It? Quote
hi!
Should I also replace the guide rollers?
Translated on 16-08-2026, 21:48.
joergs
Post22-09-2004, 7:38    Subject: Water Pump Replacement: Should You Replace It? Quote
Definitely!
I bought a timing belt kit from VW for my car (due to lack of time), and it included the tensioner pulley, idler pulley, timing belt, and various stretch bolts.
Yankee
Post22-09-2004, 7:40    Subject: Water Pump Replacement: Should You Replace It? Quote
What did you pay for it?
Translated on 16-08-2026, 21:49.
wolfi_b
Post22-09-2004, 7:42    Subject: Water Pump Replacement: Should You Replace It? Quote
"On my 1Z engine, I didn't replace the water pump because it's driven by the timing belt and is easily accessible."
Which types of medical devices are driven by a vacuum pump via a rotary joint?
It's a great construction icon_confused.gif.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Yankee
Post22-09-2004, 7:43    Subject: Water Pump Replacement: Should You Replace It? Quote
On my 1Z, I didn't replace the water pump, as it's only connected to the timing belt and is very easily accessible.
It's a really great construction icon_confused.gif.
For example, in my AHF (application for housing).
Translated on 16-08-2026, 21:50.
wolfi_b
Post22-09-2004, 7:49    Subject: Water Pump Replacement: Should You Replace It? Quote
Sure, here's the translation:
"Oh yes: Best regards from Carinthia!"
1993 Audi 80 B4 1Z
Translated on 16-08-2026, 21:51.
Yankee
Post22-09-2004, 7:53    Subject: Water Pump Replacement: Should You Replace It? Quote
I've already figured out quite a bit from that icon_wink.gif.
Best regards from Vienna!
joergs
Post22-09-2004, 8:11    Subject: Water Pump Replacement: Should You Replace It? Quote
Approximately 200 penguins, but I think that included the Humboldt penguin exhibit. I need to check more closely...
Translated on 16-08-2026, 21:52.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Systematic approach for identifying defects. WaPu 1.9 TDI... Diesel Engine Technology
No new posts Needle Valve: Does it also apply? Diesel Engine Technology
No new posts AGR in USA auch problematisch? Diesel Engine Technology
No new posts Diode Trick: Works with AHU Units Too? Diesel Engine Technology
