Mazda Diesel: Power Loss Solution Finally Found
robs
Post16-09-2003, 6:42    Subject: Mazda Diesel: Power Loss Solution Finally Found Quote
The problem was:
low performance, high fuel consumption, negative error code in the control unit.
Cause: Although Mazda was reluctant to believe that the Mass Air Flow (MAF) sensor was the cause, the individual measurement clearly showed that the MAF sensor readings were completely outside of the specified values.
Result: New engine (LMM), now great performance and fuel consumption back under 6 liters, awesome!!!!!!!
Just a heads-up for everyone who's being told: 'The error analysis in the engine control unit (ECU) showed nothing, so it can't be the mass airflow sensor (MAF).' It still could be the MAF!
Mazda only believed me after I protested, and I visited two different Mazda workshops.
It's important to acknowledge that the LMM likely rarely causes problems, and this was probably a novel experience for them.
Thank you again for all the contributions. icon_biggrin.gif icon_biggrin.gif
Greetings.
Rob's.
Translated on 10-08-2026, 2:31.
Post16-09-2003, 7:29    Subject: Mazda Diesel Power Loss: Solution Found! Quote
Hi Robs,
First of all, I'm glad to hear that you're enjoying the car again and that everything is okay.
robs wrote:
Result: new LMM (lambda sensor), now great performance and fuel consumption back under 6 liters, awesome!!!!!!!
Just a heads-up for everyone who's being told: "The error analysis in the engine control unit (ECU) showed nothing, so it can't be the mass airflow sensor (MAF)." It still could be the MAF!
"...that's what test drives are for, and a competent mechanic should know that various dynamic measurement values cannot be captured by the fault memory (and therefore also not recognized as errors by the control unit)."
Sometimes, you just have to remain persistent - even if it's difficult. icon_confused.gif
What type of LMM (Mass Air Flow Sensor) is installed in the Mazda?
Translated on 10-08-2026, 2:34.
robs
Post16-09-2003, 7:41    Subject: Mazda Diesel: Power Loss Solution Finally Found Quote
Hi Bertil,
I will check the exact model number again and then post it.
The great thing is that, despite the perceived 'incompetence,' Mazda covers the cost of replacing this part due to the long warranty. I was even worried it might be considered a 'wear and tear' item, so I don't know the price or anything else about it.
See you soon, and greetings from Stuttgart.
Translated on 10-08-2026, 2:36.
No new posts Steering play VW T5/T6 (solution) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mazda 626 Diesel: Power Loss & Jerking Diesel Engine Technology
No new posts T4 ACV: Low Boost Pressure? Solution Found! Diesel Engine Technology
No new posts LMM Failure: Mazda Performance Issues Diesel Engine Technology
No new posts The solution to the puzzle!!! 1Z power loss Diesel Engine Technology
