Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post15-01-2010, 12:57    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Hello.
My dealer told me today that the engines listed in the title only differ in the data set within the engine control unit? Is that correct?
Sure, here's the translation:
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 09-07-2026, 14:31.
Back to top Profile PM Email
Post15-01-2010, 16:03    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
To the best of my knowledge, yes.
Translated on 09-07-2026, 14:32.
RennDiesel
Post16-01-2010, 19:30    Subject: Re: Differences between the Audi A4 2.0 TDI 120hp and 2.0 TDI 143hp engines Quote
pa-mm6 wrote:
Hello.
MFG
As far as I know, the 143 hp engine is available as both a 2-valve and a 4-valve version. The 2-valve version comes with a DPF (Diesel Particulate Filter).
Post16-01-2010, 20:49    Subject: Re: Differences between the Audi A4 2.0 TDI 120hp and 2.0 TDI 143hp engines Quote
RennDiesel wrote:
pa-mm6 wrote:
Hello
MFG
As far as I know, the 143 HP engine is available as a 2-valve and a 4-valve version. The 2V version comes with the DPF.
The 2.0 TDI engine with 2 valves has been discontinued for a long time.
Translated on 09-07-2026, 14:34.
Post17-01-2010, 11:56    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Hello Rainer and everyone else, since we're at it:
My parents want to get a Skoda Yeti, but for us, front-wheel drive is sufficient. However, the only option with front-wheel drive is the 2.0 TDI diesel engine with 110 horsepower, while the all-wheel drive version has the same engine with 140 horsepower. Unfortunately, I haven't been able to find the 110 horsepower model at any dealerships around here. Can we assume that the 110 horsepower and 140 horsepower engines are largely the same? Does anyone know more?
Translated on 09-07-2026, 14:35.
Post17-01-2010, 13:30    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
The new 2.0 CR entry-level model boasts 110 horsepower.
Among them are the 1.6 CR engines with 105 and 90 horsepower.
The 110 engine was, until recently, also the basis for the Bluemotion Passat.
From the Skoda homepage:
Emission class: EU 5 / DPF
Installation orientation: mounted horizontally at the front.
Compression ratio: 1:16.5
Fuel mixing preparation | Common-rail injection
Power - kW (hp) at rpm: 81 (110) / 4,200
Fuel - Octane: Diesel, minimum 51 Cetane.
Engine type: R4 diesel engine, turbocharger with variable geometry, DOHC (double overhead camshaft), 4 valves per cylinder, timing belt.
Engine displacement - cm³: 1968.
Drill hole / Bore - mm: 81.0 x 95.5
Maximum torque - Nm/min-1: 250 / 1,500 - 2,500
They sound very similar, the 140 and 170 horsepower 2.0-liter engines.
Recognizable by its 4-valve design and likely internally geared dual overhead camshafts.
Unlike the BMR (4V PPD), which has two ZR wheels, one for each NW.
The CR pump probably needed space.
2.0 4V CR
http://www.volkswagen.de/etc/medialib/vwcms/virtualmaster/de/Models/golf0/golf_6/content.Par.0149.Image.jpg/gl2667_2009_660x420.jpg
2.0 4V PPD
http://www.volkswagen.de/etc/medialib/vwcms/virtualmaster/de/Models/passat/passat/content.Par.0144.Image.jpg/PA3174_2006_WirtQualiM6_660x420.jpg
Translated on 09-07-2026, 14:37.
pax
Avatar-pax
2000 Volkswagen Passat
Post17-01-2010, 14:07    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
2.0 TDI mit 2V gibts schon lange nicht mehr...
In the current Octavia, the 2.0 TDI engine with 140 horsepower is still listed in the specifications.
Bye.
peace
Translated on 09-07-2026, 14:40.
Post17-01-2010, 14:27    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Okay.
A friend of mine is supposed to get a Skoda Octavia 140 as a company car.
Let's see if it will be the 2V-PD or the 4V-CR.
It's already ordered.
Post17-01-2010, 15:56    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Okay, I've read all the specifications from the manufacturer. The question remains: are there enough similarities that a software change wouldn't be critical and would allow for the 140 hp? The price difference is only due to the all-wheel drive, which gives me some hope. However, we don't need all-wheel drive, so the only option left, besides the 1.2 TSI, is the smallest engine.
Translated on 09-07-2026, 14:41.
Post17-01-2010, 16:37    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Just saw that the Yeti with a 110 horsepower engine only has a 5-speed gearbox...
Post17-01-2010, 18:55    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Will it be the MQ250 - without a synchronized reverse gear?
What the G5 has, even with its 105 horsepower, is a 6-speed gearbox, which has been "bored out" (presumably referring to modifications to the engine).
Translated on 09-07-2026, 14:42.
Post17-01-2010, 19:07    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
2.0 TDI CR 81kW (110PS), 250Nm -> 118kW (160PS), 320Nm
According to my colleagues, that type of vehicle hadn't been used before.
harj
Post17-01-2010, 21:15    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
It will be the MQ250 - without a synchronized reverse gear.
What the G5 has, even with its 105 horsepower, is a 6-speed gearbox, which has been 'bored out' (presumably referring to modifications to the engine).
Hello Martin,
Is there a way to improve the ease of engaging reverse gear in the transmission?
'Best regards.'
Sepp.
Translated on 09-07-2026, 14:43.
Post17-01-2010, 21:17    Subject: Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp engines in the Audi A4 Quote
Are there valid reasons not to perform a performance upgrade due to the transmission? Is the transmission suitable for more than 250 Nm of torque? If everything fits, I can recommend it. It's a shame about the 5 gears, but 6 gears are only available with all-wheel drive.
Translated on 09-07-2026, 14:44.
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
No new posts Disable ESP: 2.0 TDI 143HP Seat Ibiza (2015) Electrical Systems, Vehicle Electronics, Multimedia
No new posts 2.0 TDI PD Injectors: VW Audi Performance Diesel Engine Technology
No new posts Audi A3 8PA 2.0 TDI BMM / 03/2006 / Control Modules 3.8, ... Upload
