Intake System: Oil and Carbon Deposits
C4Avant
Post11-09-2003, 13:14    Subject: Intake System: Oil and Carbon Deposits Quote
Hi everyone, I discovered this forum while browsing the internet yesterday, and I have to say it's great.
Here's my question: I drive an A6 2.5 TDI AEL, manufactured in June 1996, and this weekend I had to replace the pressure hose from the intercooler to the intake manifold. While doing so, I noticed that the entire intake system, starting from the turbocharger, is completely full of soot and oil deposits.
Can someone perhaps tell me where this might be coming from?
Best regards, Stephan.
Translated on 05-09-2026, 9:00.
Alois
Post11-09-2003, 14:03    Subject: Intake System: Oil and Carbon Deposits Quote
Hello.
First, read what has already been written about it. Look for 'Druckrohr' (pressure pipe) and 'Öl' (oil). icon_wink.gif
Translated on 05-09-2026, 9:01.
ideeAlist
Post11-09-2003, 16:00    Subject: Intake System: Oil and Carbon Deposits Quote
I'm focusing on the long-term consequences of the AGR icon_wink.gif.
see
Translated on 05-09-2026, 9:02.
C4Avant
Post11-09-2003, 19:47    Subject: Intake System: Oil and Carbon Deposits Quote
You're welcome. I'll start looking for it.
Markus H.
Post12-09-2003, 0:18    Subject: Intake System: Oil and Carbon Deposits Quote
Could you please share the mileage of your AEL?
I'm interested, especially because of the deposits.
Thank you.
Translated on 05-09-2026, 9:03.
C4Avant
Post14-09-2003, 21:54    Subject: Intake System: Oil and Carbon Deposits Quote
Maximum speed: approximately 230 km/h (with chip from Nothelle, 160 hp), mileage: 267,000 km.
DirkC4
Post17-09-2003, 13:50    Subject: Intake System: Oil and Carbon Deposits Quote
ideeAlist wrote:
I'm concerned about the long-term consequences of the AGR icon_wink.gif.
see
Regards
Absolutely correct!
after I disconnected them (solution: metal plate), everything remains clean icon_wink.gif.
(AAT 270,000 km)
Please provide the text you would like me to translate from German to English.
Translated on 05-09-2026, 9:04.
garth.brooks
Post19-09-2003, 22:48    Subject: Clean Intake Manifold: Improve Engine Performance Quote
Hello.
I once posted the following text:
I used a steam cleaner. It was urgently needed, as there was up to 5mm of buildup in some areas.
After that, the manifold is clean, but everything around you looks like a complete mess.
DON'T DO IT IN YOUR OWN GARDEN! (Use your mother-in-law's garden instead!)
Okay, I've disconnected the EGR valve, and the soot belongs in the exhaust, not in the engine!
Translated on 05-09-2026, 9:06.
Manuel Thomas
Post20-09-2003, 8:22    Subject: Intake System: Oil and Carbon Deposits Quote
Did cleaning the intake manifold have any effect on performance or soot production?
I've now reached 218,000 km, and I'm considering doing the same thing!
What about the ventilation ducts in the control room? Are those also narrowed?
Manuel.
Translated on 05-09-2026, 9:07.
DirkC4
Post20-09-2003, 9:16    Subject: Intake System: Oil and Carbon Deposits Quote
Manuel Thomas wrote:
How about the fresh air ducts in the ZK, are those also so constricted?
Yes.
But the worst thing I saw was the condition of the intake valves...
Translated on 05-09-2026, 9:08.
Manuel Thomas
Post20-09-2003, 9:19    Subject: Intake System: Oil and Carbon Deposits Quote
Did you just leave it like that, hoping for the broken AGR valve to self-clean?, or did you manually intervene?
Manuel.
DirkC4
Post20-09-2003, 9:31    Subject: Intake System: Oil and Carbon Deposits Quote
Did you just leave it like that, hoping for the broken EGR valve to have a self-cleaning effect?, or did you stick your finger in there?
Manuel
No.
It doesn't clean itself.
I had the cylinder head removed, and then I took out the valves, etc.
Translated on 05-09-2026, 9:09.
DirkC4
Post20-09-2003, 9:36    Subject: Clean Intake Manifold: How-To Guide Quote
garth.brooks wrote:
Oh yeah, the EGR has been disconnected since then; soot belongs in the exhaust, not in the engine!
Does one actually pass the emissions test with a disconnected EGR valve?
(assuming the examiner knows nothing about it?)
Translated on 05-09-2026, 9:10.
Manuel Thomas
Post20-09-2003, 9:39    Subject: Intake System: Oil and Carbon Deposits Quote
Yes, the leave of absence is not a problem!
No, I certainly wouldn't remove the head for that, but what other ways are there to clean the channels in the ZK (amplifier)?
Manuel.
Translated on 05-09-2026, 9:11.
ideeAlist
Post20-09-2003, 9:41    Subject: Intake System: Oil and Carbon Deposits Quote
To my knowledge, yes, because NOx (which is increased when the EGR system is faulty) is not measured, but only CO, CxHy, and soot. These three values are actually better when the EGR system is defective.
eike
Post20-09-2003, 20:00    Subject: Intake System: Oil and Carbon Deposits Quote
Yes, the AU is not a problem!
Manuel
I once had the following idea:
1. Remove the glow plug and use compressed air to blow out the cylinder from that opening, ensuring that everything is cleared out and nothing falls in.
2. Attach a small bottle brush, gun cleaner, or similar tool to a cordless screwdriver and use it to clean the intake channel.
Probably, we first need to put the motor in a suitable position. Then, theoretically, it could work quite well. However, I haven't actually done it yet. But it's probably going to be as unpleasant as using a steam cleaner new_tomato.gif.
Eike.
Translated on 05-09-2026, 9:13.
No new posts Air leak in the intake system On-Board Diagnostics (OBD)
