No power, ESP control on
Quattrpit
Post14-09-2003, 9:18    Subject: No power, ESP control on Quote
Hello everyone,
I'm having a major problem with my 1.9 TDI Golf Variant (100 hp), manufactured in October 2001.
'When the engine is cold, it runs perfectly fine. However, when it's warm, I have no power; it starts to jerk violently, and then the ESP control system activates. If I briefly turn off the ignition while driving, I might get lucky, and the problem disappears. VAG (Volkswagen Group) says that two injector pump elements are defective, but I'm not entirely convinced because they wouldn't work again after turning off the ignition.'I hope you can help me with this somehow.
Translated on 21-07-2026, 13:08.
Quattrpit
Post14-09-2003, 15:34    Subject: No power, ESP control on Quote
Does anyone here have any idea what this could be?
Translated on 21-07-2026, 13:10.
donalexo
Post14-09-2003, 16:14    Subject: No power, ESP control on Quote
Hello Quatrpitt!
Unfortunately, I'm not very familiar with PD motors. Therefore, I can only make guesses, which may be incorrect!
Important and relevant information would include things like the engine code, the current mileage of the engine, etc.
The ESP light definitely indicates an engine malfunction. What error codes are stored in the system's memory?
Please read this carefully (or have it read) and post it here!
I believe I read somewhere (please correct me if I'm wrong) that PD engines sometimes have issues with the speed sensor located on the cylinder head.
Perhaps this "geber" is the one to blame.
Have you checked the temperature sensors yet? If the problem only occurs when the engine is warm, that smells suspiciously like a faulty temperature sensor to me!
Have fun and good luck with troubleshooting.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 21-07-2026, 13:12.
emil
Post15-09-2003, 23:27    Subject: No power, ESP control on Quote
'That's correct - the ESP lamp is lit and error code 17xxx appears, depending on which pump element is faulty.'
These are the pump nozzle elements.
I also had that issue with my Audi A3, which had a 130 horsepower TDI engine.
'I just bought a Skoda Superb with a V6 TDI engine, and it has a power box installed that boosts the horsepower to 183. I haven't had any problems with it, and on a flat road, it reaches approximately 248 km/h according to the speedometer.'
I will not buy another 'Pumpe-Düse' engine, as the pumps in all of my friends' cars have failed between 20,000 and 100,000 kilometers.
Dear VAG employees,
TEST FIRST, THEN SELL!!!!!!!!!!!!!!!!!!!!
Translated on 21-07-2026, 13:14.
Quattrpit
Post16-09-2003, 23:09    Subject: No power, ESP control on Quote
hello
I think I'm a little further with my problem now; it seems to be a contact issue in the engine compartment. In the meantime, the oil level indicator and the air conditioning have also stopped working. I will now look for the central ground point in the engine compartment. I think that's where the fault lies. Oh yes, I don't know the engine code at the moment, but this car has almost 160,000 km (approximately 99,000 miles) on it in just under 2 years. icon_wink.gif
Translated on 21-07-2026, 13:16.
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 C5 2.5 V6 TDI: No Power Above 3000 RPM Diesel Engine Technology
No new posts No T4 Acv performance Upload
No new posts VW T4 AJT: No Power? Troubleshooting Guide Diesel Engine Technology
No new posts Warm-up: No Power Output Diesel Engine Technology
