A3 5V Turbo: Poor Performance Issues
racer
Post05-09-2003, 20:02    Subject: A3 5V Turbo: Poor Performance Issues Quote
Hello!
I am aware that this is not a diesel vehicle, but it would still be helpful if you could provide me with some information!
The problem vehicle is an A3, manufactured in 2000, with a turbocharged 5-valve engine producing 150 horsepower.
The problem becomes noticeable during normal acceleration, as there is clearly a lack of power! Instead of the expected 1.6 bar of boost pressure, my car only achieves 1.25 bar.
In addition, there's a slight hesitation or power loss, but it's barely noticeable.
'Work completed so far: LMM attempted, no success.'
Turbocharger replacement - unsuccessful.
Boost pressure solenoid valve - no success.
Exhaust system - visual inspection (catalytic converter): everything is in order!
Charging hoses, vacuum hoses - visual inspection, all OK!
According to the customer, the problem appeared overnight.
Have fun pondering! And thank you in advance for your help!
Best regards, L.G. Racer.
Translated on 21-10-2026, 18:06.
Marco
Post06-09-2003, 8:30    Subject: A3 5V Turbo: Poor Performance Issues Quote
How about the AGR valve?
Translated on 21-10-2026, 18:07.
Julian
Post06-09-2003, 18:56    Subject: A3 5V Turbo: Poor Performance Issues Quote
I would suspect misfires. Replace (or check) the four ignition coils and inspect the distributor.
* Check ignition timing, check lambda function, clean oxygen sensor.
*if none of this works: compression test
Translated on 21-10-2026, 18:08.
Michael II
Post06-09-2003, 20:48    Subject: A3 5V Turbo: Poor Performance Issues Quote
Was the error memory read? Are there any other data available from test drives?
PS: What specific model of machine is being referred to here?
Tschüss
Michael II
Translated on 21-10-2026, 18:09.
racer
Post18-09-2003, 17:27    Subject: SEO-Optimized Website: Tips & Tricks Quote
Hello friends!
Thanks again, it turns out it was the control unit.
I'm sorry I didn't get back to you sooner; things were a bit behind schedule.
Thank you very much.
Sincerely,
Racer!!
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Poor AFN performance On-Board Diagnostics (OBD)
No new posts Poor performance at full throttle. Diesel Engine Technology
No new posts Turbo Failure: No More Power? Diesel Engine Technology
No new posts AHF: Poor Compression - Causes & Solutions Diesel Engine Technology
