A4 Fuel Injector Control Module Replacement
Lois
Post26-09-2003, 9:05    Subject: A4 Fuel Injector Control Module Replacement Quote
Hello.
I'm having problems with the engine control unit (ECU) in my Audi A4 1.8 gasoline car.
The fuel pump is not working, but it starts working again when I try a different control unit.
Has anyone heard of anyone repairing a part like that?
Perhaps only a power transistor in that component is defective.
Translated on 20-10-2026, 10:33.
Post26-09-2003, 9:22    Subject: A4 Fuel Injector Control Module Replacement Quote
First, we need to see if we can still access the device through its diagnostic interface.
If so, read the error codes. The outputs of control units are typically short-circuit proof.
If you can successfully read the access data and error memory, take the device to a radio/television technician or a computer monitor repair specialist so they can take a look at it.
If diagnostic access is not possible, check (or have checked) the power supply/stabilization in the control unit. If everything is okay there, the situation looks bad -> it's likely scrap.
Briefly: A diagnostic system is essential.
Translated on 20-10-2026, 10:34.
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Defective Control Unit: What to Do? On-Board Diagnostics (OBD)
No new posts Faulty Control Unit: Diagnosis & Repair On-Board Diagnostics (OBD)
No new posts Faulty T4 engine control unit, 2.5 TDI ACV On-Board Diagnostics (OBD)
No new posts Freelander: Faulty ECU? Troubleshooting Guide. On-Board Diagnostics (OBD)
