AFN Engine Control: N109/N108 Modules
hammuts
Post04-11-2003, 12:12    Subject: AFN Engine Control: N109/N108 Modules Quote
Control N109 / N108.
In the wiring diagram for AFN engines with manual transmissions, revision 10/96, issue 01.97, the N109 (cut-off valve) is supplied by the control unit via connector T68/51, and the N108 (valve for injection start) is supplied via connector T68/53. In all other wiring diagrams I am familiar with, it is the opposite. When checking the wiring harness, the wire connection between connectors T68 and T3 does correspond to this wiring diagram, but surprisingly, the cable color is reversed! This is not a mistake, but an original VAG specification.
Does anyone have an explanation for this?
Thank you and...
Hartmut.
Translated on 28-07-2026, 16:48.
Back to top Profile PM Email
mersente
Post14-02-2004, 0:08    Subject: AFN Engine Control: N109/N108 Modules Quote
VW wiring diagrams have always been something to be approached with caution; it's advisable to use your own judgment and correct any errors that may have been included by VW.
Translated on 28-07-2026, 16:49.
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts Ansteuerung des N108 Diesel Engine Technology
No new posts Solenoid Valve N109 VP37 Diesel Engine Technology
No new posts 1Z SBV - N108 On-Board Diagnostics (OBD)
No new posts AKU 1.7 SDI & N108: Specs & Info On-Board Diagnostics (OBD)
