Audi Timing Belt Interval: When to Replace? (Solution)
Michael II
Post24-09-2003, 7:21    Subject: Audi Timing Belt Interval: When to Replace? Quote
Audi A2
- 4-cylinder, 4-valve gasoline engines (1.4L), no scheduled maintenance interval.
- 3-cylinder TDI pump nozzle injectors, service interval every 90,000 km.
Audi A3 from 1997 onwards.
- 2V gasoline engines (1.6L): no scheduled maintenance interval.
- 5V gasoline engines (1.8L / 1.8L Turbo, excluding the S3 model): every 180,000 km.
- S3 1.8L 5V Turbo, up to and including production in May 2000: every 180,000 km.
- S3 1.8L 5V Turbo from production month (MJ) 2001, every 120,000 km.
- TDI engines up to manufacturing date MJ 1999 (X), every 60,000 km.
- TDI engines from manufacturing year 2000 (Y) to manufacturing year 2001 (1), every 90,000 km.
- TDI engines from production year 2002 onwards: every 120,000 km.
- TDI engines from production year 2003 onwards: every 150,000 km.
- TDI pump-injector engines should be serviced every 90,000 km.
Audi TT, starting from the year 1999.
- 5V gasoline engines (1.8L turbo, 132 kW): maintenance every 180,000 km.
- 5V gasoline engines (1.8L turbo, 165 kW) manufactured up to and including model year 2000: maintenance every 180,000 km.
- 5V gasoline engines (1.8L turbo, 165 kW) from model year 2001 onwards: service interval every 120,000 km.
Audi 80 / Audi 90 from 1987 - 1995.
- 4-cylinder, 2-valve gasoline engines, all requiring maintenance every 120,000 km.
- 5-cylinder gasoline engines (2.2L turbo / 2.3L), all requiring maintenance every 120,000 km.
- V6 2V gasoline engines (2.6L / 2.8L): no scheduled maintenance interval.
- TDI engines: service every 90,000 km.
Audi A4 (B5) from 1995 to 2001.
- 4-cylinder, 2-valve gasoline engines (1.6L), no scheduled maintenance interval.
- 4-cylinder, 5-valve gasoline engines (1.8L), up to manufacturing date May 1999: service interval every 120,000 km.
- 4-cylinder, 5-valve gasoline engines (1.8L), from model year 2000 onwards, requiring maintenance every 180,000 km.
- 4-cylinder, 5-valve gasoline engines (1.8L turbo), all requiring maintenance every 120,000 km.
- V6 gasoline engines (2.4L / 2.8L): maintenance every 120,000 km.
- V6 5V gasoline engines, 2.7L turbo, except for the RS4 models, all with a maintenance interval of 120,000 km.
Use repair kit 07819847.
- 1.9L TDI engines up to manufacturing year 1999 (X), AHH engine: every 60,000 km.
- 1.9L TDI engines up to manufacturing year 1999 (model X), excluding those with the AHH engine code, require maintenance every 90,000 km.
- 1.9L TDI engines from manufacturing year 2000 (model code Y), every 90,000 km.
- All 1.9L TDI "Pump Duse" engines, every 90,000 km (approximately 56,000 miles).
- 2.5L V6 TDI engines: service every 120,000 km.
Audi A4 (B6) from 2001 onwards.
Audi A4 Convertible (B6) from 2003 onwards.
- 4-cylinder, 5-valve gasoline engines (1.8L turbo), all requiring maintenance every 180,000 km.
- 4-cylinder, 5-valve gasoline engines (2.0L), all requiring maintenance every 180,000 km.
- V6 5V gasoline engines (3.0L), service interval every 120,000 km.
- 1.9L TDI "Pump Duse" engines: service interval every 90,000 km, for models from the year 2004 onwards: service interval every 120,000 km.
Audi Cabriolet (B3) up to the year 2000.
- 4-cylinder, 2-valve gasoline engines - no scheduled maintenance interval.
- 4-cylinder, 5-valve gasoline engines (1.8L), all requiring service every 120,000 km.
- 1.9L TDI engine, up to and including production month June 1999 (model code X), every 90,000 km.
Audi 100 / A6 (C4) 1991 - 1997
- 5-cylinder gasoline engines (2.2L turbo, 2.3L), all requiring maintenance every 120,000 km.
- V6 5V gasoline engines (2.8L), service interval every 120,000 km.
- 4.2L V8 gasoline engine, service interval every 120,000 km.
- 1.9L TDI engines: service every 90,000 km.
- 2.4L diesel engine, service interval every 120,000 km.
- 2.5L TDI engines: service every 120,000 km.
Audi A6 (C5) from 1998 onwards.
- 4-cylinder, 5-valve gasoline engines (1.8L), all requiring service every 180,000 km.
- 4-cylinder, 5-valve gasoline engines (1.8L turbo), all requiring service every 120,000 km.
- V6 5V gasoline engines (2.4L without 125 kW), every 120,000 km.
- V6 5V gasoline engines (2.4L, only 125 kW), maintenance every 180,000 km.
- V6 5V gasoline engines, 2.7L turbo, service interval every 120,000 km.
- V8 gasoline engine, except for the RS6 models, requires servicing every 120,000 km.
- 1.9L TDI "Pump Duse" engines: service interval every 90,000 km.
*-RS6: Check every 30,000 km, replace every 60,000 km.
Audi V8 (D1) from 1989 to 1994.
- 3.6L V8 gasoline engine: service every 90,000 km.
Audi A8 (D2) from 1994 to 2002.
- V6 2V gasoline engines (2.8L): no scheduled maintenance interval.
- V8 gasoline engines: service interval every 120,000 km.
- 3.3L V8 TDI engine, service every 120,000 km.
Audi A8 (D3) from 2003 onwards.
- V8 gasoline engines (3.7L; 4.2L): service interval every 120,000 km.
Tschüss
Michael II
Translated on 28-07-2026, 14:46.
Ratings - Audi Timing Belt Interval: When to Replace?
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement Interval Diesel Engine Technology
No new posts VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement I... Diesel Engine Technology
No new posts ZR Change Interval: Questions and Answers Diesel Engine Technology
No new posts Timing Belt Interval AFB/AKN Engine Diesel Engine Technology
