Fresh Air Blower Control Unit: What is it?
WarLord
Post11-10-2003, 18:45    Subject: Fresh Air Blower Control Unit: What is it? Quote
'Yes, what is this? I seem to need this for my Climatronic conversion (or at least I think so). Or is this already included in the manual air conditioning system?'
Sure, here's the translation:
'By the way: Can anyone provide me with the part numbers for a Golf IV, Passat 3B, or similar Climatronic system that doesn't use a CAN bus?'
Best regards, WarLord.
Translated on 29-10-2026, 16:48.
Gremlin
Post11-10-2003, 19:02    Subject: Fresh Air Blower Control Unit: What is it? Quote
Well, 'control unit' is a bit of an exaggeration.
It's essentially a performance driver that receives an analog control signal (I believe it's 0-5V) from the Climatronic system and adjusts the fan speed accordingly.
So, you absolutely need this part. It's located directly on the fan motor, where the resistor is usually placed.
CU Gremlin.
Translated on 29-10-2026, 16:49.
WarLord
Post12-10-2003, 7:21    Subject: Fresh Air Blower Control Unit: What is it? Quote
Hm, wenn ich mir jetzt einen kompletten Heizungskasten hole, habe ich also gute Chancen so einen Leistungstreiber mitzubekommen. Okay, thank you.
Translated on 29-10-2026, 16:50.
No new posts Document A6 4B, Fresh Air Blower Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 12/00: Whistling noises from ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts Control Unit 1Z Diesel Engine Technology
No new posts GRA for AGR Valve Control Unit On-Board Diagnostics (OBD)
