GTI springs
benmen
Post12-10-2003, 21:49    Subject: GTI springs Quote
I have a Golf IV with an ASV engine (110 hp TDI).
Can I install the springs from a TDI GTI without replacing the dampers?
Benjamin.
Translated on 09-07-2026, 9:28.
Nuckelpinne_72
Post12-10-2003, 22:21    Subject: GTI springs Quote
You can already install the feathers without having any problems with the dampers.
Eibach offers the well-known Pro-Kit spring kits (lowering by 30mm) that work well with the original shock absorbers. You just need to select the correct kit (based on axle load/engine type) and have it approved by the TÜV (German technical inspection authority) after installation, using the included test report.
Die VW Sportfwahrwerksfern sind auch nur 10mm kürzer, kann mir nicht vorstellen das der Umbau irgendwas bringt und sich der Aufwand lohnt. icon_wink.gif
Greetings, Marcus.
benmen
Post12-10-2003, 22:32    Subject: GTI springs Quote
At 220 km/h, my car feels a bit unstable, and I'd like to reduce that. I hope the GTI springs will help with that...
Benjamin.
Translated on 09-07-2026, 9:29.
Nuckelpinne_72
Post12-10-2003, 22:50    Subject: GTI springs Quote
I find the original suspension on the track to be unbearably soft and floaty, whether it's the standard VW or the VW Sport version.
Forget the GTI springs, take a look at Eibach's Pro-Kit springs, Pro-System suspension, or Bilstein's B12 suspension or B8 Sprint springs.
These parts are already making a difference.
The conversion is actually quite complex; for example, you have to remove the shock absorbers from the front to replace the springs, etc., and it's not worth it for VW springs.
Good luck anyway icon_biggrin.gif.
Greetings, Marcus.
Translated on 09-07-2026, 9:30.
Dan.jel
Post12-10-2003, 23:59    Subject: GTI springs Quote
Hmm, I'm very happy with the GTI suspension!
Even at 235 km/h, there was no feeling of instability! (When I had a different engine with a chip installed.)
I've now installed a different brake system and GTI shock absorbers, so I'm selling my 'old' GTI shock absorbers and brake system.
Converting just the braking system would have been more difficult than replacing the entire set of shock absorbers. icon_rolleyes.gif
Translated on 09-07-2026, 9:31.
No new posts Feathers of steel? Transmission, Chassis, Body & Interior
No new posts Swapping suspension springs on a VW Eos Transmission, Chassis, Body & Interior
No new posts VW 1J 4Motion: Rear Spring Replacement Transmission, Chassis, Body & Interior
No new posts Fuel Injector Shim Springs for ALH Engine Diesel Engine Technology
