Passat MKB AVB: Fuel Leak Diagnosis & Repair (Solution)
Michael II
Post30-09-2003, 10:33    Subject: Passat MKB AVB: Fuel Leak Diagnosis & Repair Quote
Fuel leak at the diesel filter.
Only vehicles without fuel cooling in the area of the diesel filter are affected.
Cause:
Due to improper installation, the drain screw on the diesel filter may come into contact with the bracket. In some cases, this can lead to damage to the drain screw and cause it to break off.
Solution:
The distance between the top edge of the filter and the top edge of the holder is 25mm.
Tschüss
Michael II
Translated on 07-09-2026, 3:29.
Ratings - Passat MKB AVB: Fuel Leak Diagnosis & Repair
No new posts Document A6 4B, Fuel Leak at Cylinder Head Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B: Intermittent GRA Failure Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 TDI Engine: Interesting Documentary Diesel Engine Technology
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
