LLK 150hp PD
Go to page: 1, 2  Next
benmen
Post03-10-2003, 18:15    Subject: LLK 150hp PD Quote
I have a 110 horsepower ASV (presumably a type of engine), and I'm now installing a turbocharger from a 150 horsepower PD (presumably another type of engine) into it.
Do you think it would be worth retrofitting the LLK as well?
Which parts would I need to replace? I heard the LLK is located somewhere completely different.
Benjamin.
Marco
Post03-10-2003, 18:19    Subject: LLK 150hp PD Quote
Karma: +807 / -0   Thank you, like it!
Post03-10-2003, 18:52    Subject: LLK 150hp PD Quote
Hello Benjamin,
If you also want to achieve the 1.5 bar boost pressure of the 150 hp engine, you should consider reducing the compression ratio.
benmen
Post04-10-2003, 0:48    Subject: LLK 150hp PD Quote
Do you have any experience with that?
Do you think a thicker head gasket would solve the problem?
Benjamin.
Post05-10-2003, 9:52    Subject: LLK 150hp PD Quote
At 147,000 km, the head gasket failed in my car, and there were minor cracks in the cylinder head.
There could be many reasons for this, and I don't want to rehash everything right now.
It's certainly not a good idea to have such high boost pressure with the corresponding fuel injection volume without reducing the compression ratio.
Therefore, I can't tell you that with boost pressure x, the ZK/ZKD will fail after y kilometers.
It will probably be fine for a while... but I personally wouldn't drive like that permanently.
benmen
Post05-10-2003, 11:31    Subject: LLK 150hp PD Quote
Does anyone know of possible measures to increase compression? Are there any specific types of ZKD?
Benjamin.
WarLord
Post05-10-2003, 11:52    Subject: LLK 150hp PD Quote
Increase compression: Have the cylinder head and block machined. Otherwise, you could also increase the boost pressure. However, what you probably want is to *reduce* the compression. The simplest solution is to apply a second layer of head gasket.
Best regards, WarLord.
benmen
Post05-10-2003, 18:51    Subject: LLK 150hp PD Quote
Okay, you're right, I misspoke. I meant 'reduction' instead.
Are there any other options besides a second one? Sure, here's the translation:
'Head poetry?'
Does anyone have any experience with this?
Benjamin.
Post05-10-2003, 19:29    Subject: LLK 150hp PD Quote
There are different thicknesses of ZKDs available, which are marked with holes.
Take the thickest one (the one with the most holes).
The friendly staff can look up the thicknesses of the seals in the parts catalog for you.
If my memory serves me correctly, having 3 holes instead of 2 would have reduced the compression ratio from 19.5:1 to 19.2:1.
Because the parts dealer was incredibly incompetent and I was completely at my wit's end, I ended up buying the ones with 2 holes. icon_rolleyes.gif
benmen
Post05-10-2003, 19:43    Subject: LLK 150hp PD Quote
Rainer, why did you want to lower the compression ratio on your vehicle?
Benjamin.
WarLord
Post05-10-2003, 19:48    Subject: LLK 150hp PD Quote
Higher boost pressure and a 10-cent tuning adjustment? Possibly. Chip tuning?
benmen
Post05-10-2003, 19:54    Subject: LLK 150hp PD Quote
Do you think a reduction of 0.3 would make a difference?
Isn't that a bit too little?
Benjamin.
Post05-10-2003, 20:21    Subject: LLK 150hp PD Quote
"The reason I wanted the thicker gasket was because of the damaged head gasket and the cracks."
0.3: better than nothing icon_smile.gif.
benmen
Post05-10-2003, 20:47    Subject: LLK 150hp PD Quote
Do you think it's possible to install two thick head gaskets on top of each other?
Benjamin.
Post06-10-2003, 8:46    Subject: LLK 150hp PD Quote
No, that's not going to work.
Albrecht
Post06-10-2003, 10:11    Subject: LLK 150hp PD Quote
If I remember correctly, having 3 holes instead of 2 would have reduced the compression ratio from 19.5:1 to 19.2:1.
There are 3 different types of gaskets available from VW. The correct gasket must be installed depending on the piston clearance. However, it does not automatically mean that the thickest gasket will always result in a specific compression ratio! It varies from motor to motor.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
No new posts PD (ARL) Engine Tuning: Performance Boost Diesel Engine Technology
No new posts AFB Engine Problems: Get Expert Advice! On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Pump Düse: ARL 150PS vs. AXR 100PS Difference Diesel Engine Technology
No new posts Seat Leon Cupra 150hp PD ARL - smoking and misfiring unde... Diesel Engine Technology
