TP Sensor Error Code: Function and Troubleshooting
robs
Post02-10-2003, 23:43    Subject: TP Sensor Error Code: Function and Troubleshooting Quote
Hello dear participants,
Unfortunately, in addition to the lack of power, my Mazda now has another defect.
The error code indicated a faulty TP sensor.
What is a TP sensor, what is its function, and could it be related to the lack of power?
Thank you for the information.
It's a Mazda 626 diesel with 110 horsepower.
Greetings.
Robs.
Translated on 20-10-2026, 19:40.
robs
Post06-10-2003, 6:01    Subject: TP Sensor Error Code: Function and Troubleshooting Quote
hello, is anyone able to answer?
It's probably the throttle position sensor.
Is that the gas chromatograph? Is it for diesel?
'Thank you.'
robs
Translated on 20-10-2026, 19:41.
Post06-10-2003, 6:20    Subject: TP Sensor Error Code: Function and Troubleshooting Quote
Hello Robs,
Unfortunately, I can't tell you what a TP sensor is. If it stands for "Throttle Position," then it's the throttle position sensor, which is essentially the accelerator pedal potentiometer. Based on my information, diesel engines with fully electronic control systems always have a throttle position sensor. There's no longer a throttle cable connected directly to the fuel injection pump (especially not with common rail systems).
Das Gaspoti is responsible for transmitting your gas commands to the EDC, so it provides the STG with information about the pressure you are applying with your right foot icon_wink.gif.
Translated on 20-10-2026, 19:42.
robs
Post06-10-2003, 7:10    Subject: TP Sensor Error Code: Function and Troubleshooting Quote
Thank you for the quick response.
I will inform you about what the TP sensor actually stands for.
I only suspected that the throttle position was...
'Thank you.'
robs
Translated on 20-10-2026, 19:43.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fails: No Function with New Sensor Electrical Systems, Vehicle Electronics, Multimedia
No new posts MAP Sensor for AKN Engine On-Board Diagnostics (OBD)
No new posts LDA Sensor: Types, Function & Applications Diesel Engine Technology
No new posts What kind of sensor is this? Diesel Engine Technology
