Coolant Problem VW Passat
Franz
Post06-10-2003, 14:24    Subject: Coolant Problem VW Passat Quote
Hello everyone,
I'm having a coolant problem with my Passat Variant TDI 90 hp, manufactured in 09/97. I recently filled the coolant up to the maximum level. Now, the level has dropped significantly to below the bottom edge of the expansion tank, where the hoses are connected. However, the coolant level is now stable. I only lose coolant when I refill it, and then it drains out relatively quickly. I can't find anything obvious. There's just a slightly oily residue on the bracket under the expansion tank. I had a similar problem with my Golf a few years ago, and in that case, the tank had a hairline crack. However, the shape of the expansion tank on the Passat is different, and it's securely mounted with three screws.
'I have a question for you all: Has anyone here ever experienced a leaking expansion tank on a Passat? I'm hesitant to buy one myself. I would appreciate any advice.'
Best regards, Franz.
Translated on 25-09-2026, 23:43.
x world one
Post06-10-2003, 14:47    Subject: Coolant Problem VW Passat Quote
I had a leaky hose on my car. It was really difficult to find the hole.
I basically ran my hand along each coolant hose, and at the same time, I pressed on the hose near the radiator with my other hand, creating pressure in the system. That's how I accidentally found the tiny hole, which was in a slight bend of the hose. It wasn't visible to the eye and seemed to only leak under higher pressure.
Spritmonitor
Translated on 25-09-2026, 23:45.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Fuel Pump for VW Passat AFN Engine Diesel Engine Technology
