Document MKB AKF, Performance Issues, Error 17964 (Solution)
Michael II
Post06-10-2003, 15:09    Subject: Document MKB AKF, Performance Issues, Error 17964 Quote
Performance issues, engine running in limp mode, error code 17964, turbocharger boost control - operating limit exceeded.
Cause:
Plastic connection piece between the vacuum line and the vacuum container in the wheel arch has been {DAMAGED/BROKEN/FAILED}.
Solution:
Rotate the vacuum container 180 degrees so that the connection faces downwards.
Install a new, approximately 730mm long, non-stressed vacuum hose.
Tschüss
Michael II
Ratings - Document MKB AKF, Performance Issues, Error 17964
No new posts Documentation: Performance Issues, Error 17964, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TDI Turbocharger Problem: Boost Control Error 17964 Diesel Engine Technology
No new posts Engine Idle High: 1250 RPM, Low Power, 6 Errors On-Board Diagnostics (OBD)
No new posts 3-cylinder, 1.4L, diagnostic trouble code 17964 Diesel Engine Technology
No new posts Audi A4 B5 1.8T - 17964 Gasoline Engine Technology
