Hello!
On my T4, ACV model year 2000, the MFA (Multifunction Display) has the following functions:
Outdoor temperature displayed in the lower half of the screen (also shown in the central display).
Average consumption.
Current consumption.
Driving time.
Average speed.
"But there's no oil temperature reading??? According to other T4 drivers, it should be displayed."
I would like to have those. Perhaps the instrument cluster is just incorrectly coded? The current coding is: 08111.
Sure, please provide the text you would like me to translate from German to English. I will only provide the translation.
VW has three different instrument clusters (also known as dashboards).
- Low-profile version with tachometer and digital clock.
- Midline version with tachometer and multifunction display.
- Highline version with tachometer, multifunction display, and navigation display unit.
In the 1999/2000 model years, ALL vehicles from Volkswagen were switched to the new CAN-BUS system.
This is a bus system that is used for data transmission between the control units.
which also includes the KI (combination instrument).
To determine whether a Midline MFA or a Highline MFA is installed,
Looking at the upper half of the display in the center of the instrument cluster...
If you see symbols (airbag, handbrake, etc.), then you are simply looking at the standard MFA (Multi-Function Display).
The difference between Midline and Highline MFA can also be seen on the back of the AI device:
On the right and left sides, you can see a 32-pin connector each.
If there is an additional 20-pin connector in the center, it indicates a Highline instrument cluster (with navigation).
It's best to find the pin configuration of the control unit (old/new) using a wiring diagram.
AI part number breakdown:
The first 3 characters represent the model:
7D0 xxx xxx = T4
The middle three characters represent the control command.
xxx 919 xxx = WITHOUT CAN-Bus (up to model year 2000).
xxx 920 xxx = Compatible with CAN-Bus (from model year 2000 onwards).
The last three digits indicate the features.
xxx xxx 8xx = Display in km/h.
xxx xxx 9xx = Display in mph.
It appears that in the T4 AI, the second-to-last position is reserved for the tachograph code.
7D0 920 80x = Lowline version.
7D0 920 82x = Midline version.
7D0 920 84x = Highline version.
There is no clear correspondence for the last digit, as it is referred to differently in the various model years.
(Please note: The last two digits are subject to change without notice.)
AI coding:
Everything is beeping and flashing after the new instrument cluster was connected.
That's normal; many functions may be activated that haven't yet been connected or disabled through diagnostics.
In order to operate the AI correctly, various additional functions need to be activated or deactivated.
The adjustments are performed using VAG-COM (on VW/Audi devices with VAS 1551 and 5051/52).
Here are only the most important AI settings via VAG-COM:
Select STG 17 (combination instrument).
STG Coding -> Function 07.
Encoding number (example): 04142
The first two digits of the code indicate the extra options.
00 - no extra options.
+01 - Brake pad wear indicator active.
+02 - Seatbelt warning indicator active.
+04 - Windshield washer fluid level warning indicator active.
6 - Navigation active.
Error code (example): 22142 (modified with VAG-COM).
Instead of just displaying the windshield washer fluid level, the system now also includes navigation and seatbelt warning indicators (02+04+16=22).
The third code position is responsible for country selection.
1 - Rest of the world (24-hour clock)
2 - USA (12:00 PM)
3 - Canada (12:00 PM)
4 - UK (24-hour clock)
5 - Japan
6 - Saudi Arabia
7 - Australia
The fourth digit in the code indicates the engine variant:
3 - No service intervals (2002+).
4 - 4-cylinder (1999-2001)
5 - 5-cylinder (1999-2001)
6 - 6-cylinder (1999-2001)
The fifth code position indicates the distance indicator.
1 - 4345
2 - 3528
3 - 4134
4 - 3648 (2002+)
Set or change the language of the AI (Highline MFA).
Select the STG 17 combination instrument.
Adjusting the ECU -> Function 10 -> Channel 4.
Select language:
00001 - English (English)
00002 - English (English)
00003 - French (Französisch)
00004 - Italian (Italian)
00005 - Spanish (Spanish)
00006 - Portuguese (Portuguese)
Set service interval display.
Finally, you can adjust the service interval display.
Adjusting the ECU -> Function 10.
The values indicate the time or distance until the next inspection. If a smaller value is desired,
Simply subtract the value from the normal value (e.g., 00009 for an inspection due at 9000 km).
-> Channel 10 ("OIL" message)
The new adjustment value is "00015" for inspections every 15,000 km. This value is specified in units of 1,000 km (15 x 1,000 = 15,000 km).
-> Channel 11 ("INSP 01" message)
The new adjustment value is "00030" for inspections every 30,000 km. This value is specified in increments of 1,000 km (30 x 1,000 = 30,000 km).
-> Channel 10 ("INSP 02" message)
The new adjustment value is "00036" for the annual inspection, and it is specified in increments of 10 days (36 x 10 = 360 days).
Best regards, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
