MFA: What is required for a retrofit?
WarLord
Post04-10-2003, 14:41    Subject: MFA: What is required for a retrofit? Quote
I have a question (again): What is needed to retrofit a multifunction display (MFA) onto a Passat 35i 3A5? The device has a speedometer with an analog clock and a digital odometer.
Best regards, WarLord.
DocSnydor
Post05-10-2003, 12:37    Subject: MFA: What is required for a retrofit? Quote
You definitely need a combination instrument for the MFA (Multi-Function Display) and a windshield wiper lever with MFA functionality. I'm not sure what other sensors you might need (e.g., oil temperature), as I'm not familiar with that. You definitely need a combination instrument that no longer has the connection for the vacuum hose (for fuel consumption measurement).
WarLord
Post05-10-2003, 12:47    Subject: MFA: What is required for a retrofit? Quote
You're welcome. I assume the vacuum port is only necessary for gasoline engines to determine the throttle position, correct?
DocSnydor
Post06-10-2003, 9:37    Subject: MFA: What is required for a retrofit? Quote
Yeah, that's what I imagine too...
You can actually find those quite often on eBay.
x world one
Post06-10-2003, 10:00    Subject: MFA: What is required for a retrofit? Quote
However, I don't think it's a good idea to connect a combination instrument designed for a gasoline engine to a diesel engine. The DZM is completely wrong.
Were instrument clusters with the Multifunction Display (MFA) common in diesel-powered Passat wagons?
I've been searching everywhere for a Golf3 TDI, and they're incredibly rare.
Spritmonitor
Albrecht
Post06-10-2003, 11:15    Subject: MFA: What is required for a retrofit? Quote
Please check out the website of diesel-dirk: www.jagiella.net
Everything is described excellently there!
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Mampf
Karma: +8 / -1   Thank you, like it!
Post06-10-2003, 19:32    Subject: MFA: What is required for a retrofit? Quote
x world one wrote:
Were instrument clusters with the MFA (Multi-Function Display) common in the Passat wagon for diesel models?
MFA (Multifunction Steering Wheel) was standard equipment on all Passat 3A (35i facelift) models with the GT trim (at least for gasoline and TDI engines - I don't know about the TD).
Munch.
DocSnydor
Post07-10-2003, 8:43    Subject: MFA: What is required for a retrofit? Quote
By the way, if you can't find a combination instrument for the 35i: The one from the T4 will also fit. (At least in terms of shape; I don't know if there will be any problems due to the 5 cylinders -> incorrect readings icon_question.gif).
WarLord
Post07-10-2003, 14:41    Subject: MFA: What is required for a retrofit? Quote
Do you know if the new design fits, or only the old one? The new design would be another step up in terms of aesthetics (although I think the Passat looks very good). The one from the Golf III is ugly (I wonder if there are any available on eBay for the TDI). What about the mileage? I still have to reprogram that one (and I'll already have 167,000 km on the odometer by then).
DocSnydor
Post07-10-2003, 15:32    Subject: MFA: What is required for a retrofit? Quote
What do you understand by 'old form' / 'new form'? I'm just standing around, doing nothing.
And the mileage... that's a tricky thing.
I have an instruction manual on how to supposedly adjust the speedometers on our 35i models, but I haven't tried it yet. You need to create a custom cable (without an interface) and then connect it to the three pins on the back of the instrument cluster. The manual claims that you can then use a DOS program to adjust the speedometer. If you're interested, I can gladly email it to you (approximately 1 MB).
'Unfortunately, nothing can be accessed through OBD, as the AI systems are not yet capable of diagnostics.'
WarLord
Post07-10-2003, 20:32    Subject: MFA: What is required for a retrofit? Translating...
[Translating...]http://shop.dieselschrauber.de/product_info.php/products_id/45
DocSnydor
Post08-10-2003, 9:00    Subject: MFA: What is required for a retrofit? Quote
Oh, you mean for a T4!? Well, it won't fit, just based on the shape alone... It looks more like a Golf 4.
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do you need a DZR guide? Diesel Engine Technology
No new posts UHV in the Touran - what else is needed? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Schutzrohr am Stossdämpfer unbedingt nötig? Transmission, Chassis, Body & Interior
No new posts Airbag malfunction, new coil spring needed? Transmission, Chassis, Body & Interior
