ARL Performance Issues Below 2000 RPM
Torque-Master
Post10-10-2003, 18:38    Subject: ARL Performance Issues Below 2000 RPM Quote
Hello everyone!
I have icon_mad.gif less than 2000 1/min of thrust icon_eek.gif compared to what was originally available. In this range, it feels like icon_question.gif it's happening in a naturally aspirated diesel engine, because the engine is very slow to rev up. My turbo boost indicator also only shows about 0.5 bar. icon_question.gif
However, if I exceed 2000 rpm, the boost pressure increases sharply immediately, and in overboost mode, it reaches approximately 1.7 bar, causing the car to accelerate significantly. icon_question.gif
When driving at full throttle and maximum speed, I noticed that the pressure is no longer 1.5 bar as it used to be, but only 1.3 bar. Consequently, the engine feels a bit sluggish at higher RPMs.
I checked the mass airflow sensor, but it shows a value of approximately 730 when briefly giving it full throttle at idle, which suggests that the MAF sensor is likely functioning correctly.
Who can give me assistance with this problem? } } }
Translated on 18-10-2026, 22:19.
Post10-10-2003, 19:26    Subject: ARL Performance Issues Below 2000 RPM Quote
I had checked the mass airflow sensor, but it shows a value of approximately 730 when I briefly give it full throttle while the engine is idling, which should indicate a relatively intact mass airflow sensor.
The measurement method is useless.
In the technical article https://community.dieselschrauber.org/en/viewtopic.php?t=3128, the framework conditions are described, but unfortunately, the ARL (Arbeitslosenregister, unemployment register) is not listed.
Is the turbocharger system airtight?
Translated on 18-10-2026, 22:21.
Torque-Master
Post10-10-2003, 19:40    Subject: ARL Performance Issues Below 2000 RPM Quote
Thank you.
I took a look at the table. Does this mean I should check the air mass during idle, since there are no data entries for full load? Can the problem be detected during idle?
How can I check if the system is leak-tight?
Translated on 18-10-2026, 22:22.
Post10-10-2003, 19:52    Subject: ARL Performance Issues Below 2000 RPM Quote
Of course, are the full load data entered? icon_question.gif Please check all the measurement blocks.
For example, the ASZ (130PS TDI) engine has a typical value of 900-1250mg per injection.
Intake manifold leak after the turbocharger: Oil mist/oil stains on the pipes/hoses, louder turbocharger noise.
Ideally, insert plugs into both openings (after the charger and before the intake manifold) and apply compressed air. This will definitely help you identify where the leaks are.
Translated on 18-10-2026, 22:23.
Torque-Master
Post10-10-2003, 20:08    Subject: ARL Performance Issues Below 2000 RPM Quote
OK.
I looked at measurement block 3, but you mentioned block 10. However, both times, the values listed are for air mass.
Okay, I'll test these values in 3rd gear under full load. Unfortunately, I can't do it until next week, as I don't personally have a VAG-COM device.
'I don't see any oil mist on the outside of the hoses, but the pressure hoses are oily on the inside. The workshop said that this shouldn't happen, but it's supposedly unavoidable. They claimed that all TDI engines do this!'
Translated on 18-10-2026, 22:25.
Post10-10-2003, 20:21    Subject: ARL Performance Issues Below 2000 RPM Quote
Where exactly is the oil mist from the crankcase ventilation supposed to go? icon_smile.gif
Translated on 18-10-2026, 22:26.
Post11-10-2003, 13:16    Subject: ARL Performance Issues Below 2000 RPM Quote
Rainer K. wrote:
Are the data entered for full load? icon_question.gif Please check all the measurement blocks.
The ASZ (130PS TDI) engine, for example, has a typical value of 900-1250mg per stroke.
Hi Rainer,
I've gotten into the habit of using VAGCOM to read the desired mass airflow value directly from the engine control unit (instead of from a table). There are actually (at least in the ALH and AFN engines) two mass airflow values in the AGR measurement block: desired and actual.
As long as the actual value is not below this target value, a performance loss due to air mass should not occur, regardless of what is stated in the table.
Translated on 18-10-2026, 22:27.
No new posts Document up to KW 06/2000: Sudden noises with power loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mal was für die Physiker unter uns Diesel Engine Technology
No new posts LL3 oil not for PD under MD 02? Diesel Engine Technology
No new posts Cold Start Diesel Engine: 101 PS Below 0°C Diesel Engine Technology
No new posts Golf 3 TD AAZ: Clicking Noise Under Load Diesel Engine Technology
