Vibration in Auxiliary Belt: Causes & Solutions
Jan03
2010 Volkswagen Polo
Post03-10-2003, 14:50    Subject: Vibration in Auxiliary Belt: Causes & Solutions Quote
Hello.
I know this might have been discussed before, but maybe someone has a tip on how to get rid of these vibrations.
My auxiliary drive belt is vibrating very strongly (amplitude of about 1.5 cm), which can also be heard inside the car. In addition, there is a fluctuation (about 2 Hz), so that the vibration gets louder and quieter. icon_cry.gif The tensioner seems to still have good pre-tension (nothing is slipping). icon_rolleyes.gif What can I do about this?
I read in another forum that similar vibrations can also be caused by a loosening timing pulley. However, when I look at it from above, everything seems quiet, and only the pulley of the auxiliary belt might be wobbling slightly, perhaps by about 1mm. The engine starts perfectly, whether cold or warm. However, the multi-tooth screw is still of the old type (there's nothing marked on it).
I'm not really keen on replacing everything just based on suspicion, especially since I just installed the TDI engine (and all its components) into my Golf. Before that, I had an ABS engine in it, and the conversion wasn't something I could finish in a weekend.
Hi from Jan.
Golf III from 1994 with a 1Z engine (125,000 km).
Translated on 25-08-2026, 4:11.
Post03-10-2003, 18:27    Subject: Vibration in Auxiliary Belt: Causes & Solutions Quote
Since when has this problem been occurring?
Are the screws connecting the pulley and toothed wheel tight? Are the bearings of the alternator and other components secure?
It's definitely not a known issue. The only way to check is to go under the car and take a look.
Translated on 25-08-2026, 4:13.
Jan03
Post08-10-2003, 9:32    Subject: Vibration in Auxiliary Belt: Causes & Solutions Quote
Thanks for your tips, Rainer. I'm still working on it.
The reservoirs for the headlight, water pump, and power steering pump are all fine. The pulley seems to have some play. I've already bought a new one and will see if that makes a difference.
Hi from Jan.
Translated on 25-08-2026, 4:14.
Post08-10-2003, 10:03    Subject: Vibration in Auxiliary Belt: Causes & Solutions Quote
The tensioner for the ribbed V-belt was loose on my vehicle.
It costs €60 and can be easily replaced if you can loosen the roller (adjust the English setting to 14mm and attach it to the tension arm).
I broke down the details yesterday – pictures and text are in a different thread.
Greetings.
Translated on 25-08-2026, 4:15.
Jan03
Post12-10-2003, 21:00    Subject: Vibration in Auxiliary Belt: Causes & Solutions Quote
Well, the new pulley didn't do anything. icon_sad.gif The tensioner still has a very good pre-tension. It's probably the vibration damper. Can I replace it without having to remove the entire timing wheel from the crankshaft?
January.
Translated on 25-08-2026, 4:16.
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts Engine Noise in Car: A6 4B (1999) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about vibrations starting at approximately 12... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Strong vibrations since the accident! Transmission, Chassis, Body & Interior
No new posts Exhaust Emissions at Specific RPM Range Diesel Engine Technology
No new posts Significant smoke evacuation failure / AU exam not passed Diesel Engine Technology
No new posts Excessive soot buildup, reduced performance, and moderate... Diesel Engine Technology
