VAS 5051 Login: Passat AKN Diagnostics
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
mfdk
Post13-10-2003, 21:38    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
I am looking for the login code for my Passat, engine code AKN, manufactured in 2000.
If anyone can help me, I would appreciate the information.
mfdk
Translated on 27-08-2026, 20:05.
joergs
Post13-10-2003, 21:45    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
What do you want to do?
mfdk
Post14-10-2003, 10:35    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
I would like to increase the base value by 400 (if possible), following the schema described in several previous posts:
TDI tuning for all TDI engines except those with a 'Pumpe-Düse' (injection pump) system.
It is very important to save the old values beforehand.
for possible process reset.
01 Engine
Login ???
Channel 01 32784 Max Values (these are sliders that you can move up and down).
(can be pushed!)
Channel 02 33638 Max Values.
(Excerpt from an older post)
mfdk
Translated on 27-08-2026, 20:06.
joergs
Post14-10-2003, 10:43    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
Are they not working?
Translated on 27-08-2026, 20:07.
mfdk
Post14-10-2003, 22:58    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
@joergs
Thank you for the information.
I entered the code 11463 and found that my control unit does not support this function.
Thank you.
mfdk
Translated on 27-08-2026, 20:08.
joergs
Post14-10-2003, 23:08    Subject: VAS 5051 Login: Passat AKN Diagnostics Quote
@ joergs
Thank you.
mfdk
That shouldn't have been the right one for your issue, should it? It activates the gray setting, doesn't it?
Translated on 27-08-2026, 20:09.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Read WfS login data from Passat 3C B6 On-Board Diagnostics (OBD)
No new posts Passat 3B Airbag Error Deletion Login On-Board Diagnostics (OBD)
No new posts VAG TDI Tuning: Diagnostics & VW 5051 Diesel Engine Technology
No new posts AEL Login: Access, Adaptation & Implementation On-Board Diagnostics (OBD)
