Boost Charger: 1Z to 10ct?
Akustikus
Post15-11-2003, 17:14    Subject: Boost Charger: 1Z to 10ct? Quote
I have an old Audi 80 1Z, manufactured in 1992, with a faulty EGR valve and (of course) without a VTG turbocharger... *sniff*...
A slight amount of soot is visible at maximum load.
It can be quite helpful, especially since I drive 1000 km per week on the highway, to briefly press the 'exhaust button' if someone is tailgating you closely. icon_biggrin.gif
'But I would like to try to eliminate it by doing a '10-cent tuning,' which means slightly increasing the boost pressure.'
Unfortunately, even after studying the technical articles, I'm still not entirely sure if it's even possible for my 'Senior' model, as the articles only describe newer engines.
If so: where exactly do I need to solder in which resistor (to achieve 0.2 bar more pressure)?
And does the magnetic valve in the engine compartment also need to be replaced, if necessary?
Okay... Of course, I've implemented LDA, and the values are normal, i.e., a maximum of 1 bar.
Otherwise: Keep up the great work, this is truly the top diesel website on the internet!!!
Markus.
Translated on 10-10-2026, 14:01.
audi 80 tdi
Post15-11-2003, 20:24    Subject: Boost Charger: 1Z to 10ct? Quote
hello
"I also want to do the same thing to my engine (I have the same one), but unfortunately, I don't know exactly which wire the resistor needs to be soldered into. You can precisely determine the size of the resistor to use with a potentiometer, so you only need a rough estimate as a starting point. What chip do you have installed, and what are the effects (in terms of fuel consumption and power increase)?"
best regards, christian
Translated on 10-10-2026, 14:03.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Doku A3 8L bis 12.2000, Brummgeräusche durch Freispreche... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Potentiometer: Does Temperature Affect Its Performance? Diesel Engine Technology
No new posts Boost Increase: 10ct Tuning - The Slow Way Diesel Engine Technology
No new posts Ladedruckerhöhung AFN Motor Diesel Engine Technology
No new posts Tuning: Boost Increase & Piston Failure Diesel Engine Technology
