Login Code for Comfort Control Unit
leonsberger
Post16-10-2003, 22:18    Subject: Login Code for Comfort Control Unit Quote
Hello everyone,
Does anyone have the login code for the comfort control unit? It seems I can't make any changes otherwise.
My car: Seat Leon TDI PD, 150 horsepower, manufactured in 2002.
'Thank you.'
Translated on 22-10-2026, 4:36.
Uwe@Ross-Tech
Post17-10-2003, 2:08    Subject: Login Code for Comfort Control Unit Quote
You don't need a login code.
However, if you want to save the adjustments made with VAG-COM, you need the full version.
-Uwe-
Translated on 22-10-2026, 4:37.
leonsberger
Post17-10-2003, 7:41    Subject: Login Code for Comfort Control Unit Quote
I have a registered version, or at least I entered the activation code and it was accepted.
Uwe@Ross-Tech
Post17-10-2003, 19:01    Subject: Login Code for Comfort Control Unit Quote
Yes, but did you really purchase a license, and did you legitimately obtain the activation?
If the unlocking is legitimate, please send me a private email.
(not a private message within the forum) with the following details:
* Your full name.
* From whom did you purchase your VAG-COM license?
* License or invoice number
* Serial number and activation.
Then we will solve your problem.
-Uwe-
Ross-Tech
Translated on 22-10-2026, 4:38.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Looking for login code for comfort control unit On-Board Diagnostics (OBD)
No new posts Login Code for Comfort Control Unit in Skoda Octavia On-Board Diagnostics (OBD)
No new posts ECU Login Code: How to Find & Use On-Board Diagnostics (OBD)
No new posts AEL Motor Login Code: Start Quantity Example On-Board Diagnostics (OBD)
