René_S Guest
19-10-2003, 11:58 Subject: Water Temperature AKN |
Hello, I'm having the following problem...
According to the temperature gauge in the instrument cluster, the coolant temperature in my AKN engine barely exceeds 60°C. The needle hardly moves when the ignition is turned on.
The temperature measured on the engine block with a handheld device was approximately 85-90 °C (however, this was only after about 25 minutes, while idling, and measured with an infrared surface sensor in strong wind). The temperature at the radiator was around 70 °C.
How can I display temperature values using VAG-Com? It would be great to have a description/explanation of the channels.
Thank you very much.
René.
Translated on 27-09-2026, 16:59.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
19-10-2003, 18:09 Subject: Water Temperature AKN |
It would have been even better if you had used the search function.
Tschüss
Michael II
Translated on 27-09-2026, 17:00.
René_S Guest
19-10-2003, 18:43 Subject: Water Temperature AKN |
'Sorry, I did use the search functions beforehand, but I was missing search terms like 'target data' or 'measurement data blocks,' etc.'
Thank you again for the link.
The temperature in block 1, field number 4 is 90 °C. Does the display in the combination instrument use the same sensor?
René.
Translated on 27-09-2026, 17:01.
