A4 1.9 TDI: Error 01044 - Troubleshooting
Jackson
Post17-10-2003, 18:01    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
'The preheating light is flashing on my Audi, and the VagCom diagnostic software is showing me error code 01044: 'Control unit incorrectly coded.' However, the car is running perfectly fine!'
'I had a tuning chip installed in the engine control unit about 2 weeks ago. Could that be related to the problem? What's surprising is that I was able to drive for a whole week without any error messages.'
The preheating light has only been flashing for about a week, shortly after the engine starts.
Do you need to reprogram or re-calibrate the control unit in any way?
Jackson.
Translated on 10-10-2026, 13:14.
Post17-10-2003, 18:42    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
Hi, bad solder joint(s)?
Translated on 10-10-2026, 13:15.
Jackson
Post17-10-2003, 18:49    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
I can't imagine that, I've checked it three times.
When I clear the error memory, the code 01044 reappears immediately, or it isn't erased at all.
As I mentioned, the car is running perfectly. However, if there are cold solder joints, it might experience interruptions during operation, or the software might crash while driving.
Jackson.
Translated on 10-10-2026, 13:16.
Uwe@Ross-Tech
Post19-10-2003, 16:45    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
Is the chip the correct one for the control unit? Please compare the control unit number that VAG-COM displays (which comes from the chip) with the number on the label on the control unit.
What is your current coding? Please also provide your vehicle data: model, year of manufacture, engine code, and transmission. Then, we can check your current coding using a coding table in the repair manual.
-Uwe-
Translated on 10-10-2026, 13:17.
Jackson
Post19-10-2003, 17:52    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
Hello Uwe,
Luckily, I was able to find some old data before the chips were replaced (see below).
Okay, the engine control unit number is correct. My Audi is a B5 model, manufactured in October 1997, and it has a 5-speed transmission. I don't know what the MKB is.
Could it be that 'SG' and now 'AG' at Comp refer to shiftable and automatic transmissions? If so, that would be incorrect.
Jackson.
Old data:
VAG No: 038 906 018 S
Comp: G00SG 1621
Soft: 00002
Shop: WSC 06325
New data:
Comp: G00AG 1621
Soft: 00001
Shop: WSC 06325
Translated on 10-10-2026, 13:19.
Jan6K
Avatar-Jan6K
Post19-10-2003, 18:05    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
That's right.
AG = Automatic.
SG = Switchgear.
That definitely needs to be corrected.
Jan.
1Z5 CFHF / AHB H4D
Translated on 10-10-2026, 13:21.
Jackson
Post19-10-2003, 18:12    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
Then it seems like some kind of configuration process is needed so that the control unit knows which components are installed in the car.
But how do you do that? Does anyone have instructions for me?
Michael.
Uwe@Ross-Tech
Post19-10-2003, 18:28    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
MKB = Engine Identification Code.
'No problem, you've already found the issue. Just set the encoding back to 00002, and then you can clear the error.'
With VAG-COM:
Select control unit -> 01-Engine.
Function: Encode-07
00002 eingeben und quittieren (weiss nicht was auf dem knopf steht, es gibt ja 3 verschiedene deutsche uebersetzungen, in der englischen version ist's 'Do It!'). See:
http://www.ross-tech.com/vag-com/tour/recode_screen.html
-Uwe-
Translated on 10-10-2026, 13:22.
Jackson
Post19-10-2003, 18:51    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
Hmm, I just tried, but I can't seem to change the software version.
After confirming with DoIT, it goes back to the engine data screen, and 'Soft' and '...AG' are still the same.
Kann es sein das man sich vorher Einloggen muß? If so, how?
Michael.
Translated on 10-10-2026, 13:23.
Uwe@Ross-Tech
Post19-10-2003, 19:40    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
The documentation for your AFN (access point name) doesn't mention anything about a login being required before you can configure it. However, you could still try using the common login credentials: 01283, 11463, or 12233.
'I've also seen cases with 1.8T engines in A4s where, after a chip tuning modification, the coding options were much more limited than with the standard configuration. It was a fault on the part of the chip tuner (supposedly they used an incorrect base program from Bosch, but I'm not sure if I believe that).'
-Uwe-
Translated on 10-10-2026, 13:24.
Jackson
Post19-10-2003, 20:06    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
I've tried all the login credentials, but this thing just won't update to software version 00002. Login 01283 is giving me an error message.
I've probably tried it 30 times, and I've never seen an error message. According to the software, it should have worked. Turning the ignition on and off doesn't help either.
Michael.
Translated on 10-10-2026, 13:25.
Jackson
Post19-10-2003, 21:00    Subject: A4 1.9 TDI: Error 01044 - Troubleshooting Quote
If I reinstalled the original chips, would I then be able to change the software version to 00002, and would it remain at 00002 after the change?
I'm wondering if the chip is possibly only programmed for the engine control unit (ECU) with an automatic transmission.
Michael.
Translated on 10-10-2026, 13:26.
No new posts Timing Belt Replacement Problems: AGP, AGR, AHF, ALH &... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 01044 on CAN Gateway: How to fix it On-Board Diagnostics (OBD)
No new posts Error P0093 at 1.6 HDI Diesel Engine Technology
No new posts Gas Pedal Problem: Strange Error & Fixes Diesel Engine Technology
No new posts Firmware Update Failed: Troubleshooting & Solutions On-Board Diagnostics (OBD)
